Fuel Flow Mystery
Discussion in 'Technical' started by rlang, Sep 22, 2011.
  1. baddad457
    X 2 ditch the return line.
  2. rlang
    rlang Member
    Los Angeles
    1970 Ford Maverick
    Just replaced the old filter with a new regular inline one and ... knock on wood ... the engine didn't die. Or at least this this the first time that my "test drive" hasn't starved the engine.
    I'll venture out on a longer drive tomorrow but all indications point to this problem being solved. Thanks so much everyone!
  3. Mad_Cow
    Mad_Cow Member
    South Dakota
    "Madison"-1972 Maverick
  4. baddad457
  5. 71gold
  6. Mad_Cow
    Mad_Cow Member
    South Dakota
    what if it took and hacked the end off the line drilled a hole in my filler and ran a tube from the vapor line to the filler? would that work? seems like it would.
  7. Mad_Cow
    Mad_Cow Member
    South Dakota
    and could this be what's causing my build up in oressure and constant blown FPR's?
  8. baddad457
    If it's the line I'm thinking of, it's really small to use as a return line for an EFI setup, that should be about 5/16" I'd think. The tubing I'm thinking you're using for this is about 1/8" ?
  9. Mad_Cow
    Mad_Cow Member
    South Dakota
    no it's 5/16 or 3/8. can't remember for sure which one but i know i only baught the two sizes when i was doing my fuel set up and one fit on snuggly like it should. just dropped the gas take found the valve that's causing me porblems.. ran a search trying to find a way to bypass it.. and wouldn't you know it this is the first thread to pop up! but anyway.. fuel vapors have me in their grasp!
