Fuel gauge and sending unit issue
Discussion in 'Technical' started by heliboy, Oct 14, 2013.
  1. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    1976 Maverick 2 door
    Gotcha. I plan to take the cluster out by the middle of this next week and clean the board, grease the connections, etc. Speaking of which, how is the best way to test the regulator?
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Not just any grease, you want electrical conducting grease something like this
    [ame="http://www.amazon.com/Fulton-11755-Electrical-Contact-Grease/dp/B001446LP4/ref=sr_1_2?s=automotive&ie=UTF8&qid=1381940571&sr=1-2&keywords=conductive+grease"]Amazon.com: Fulton Electrical Contact Grease: Automotive[/ame]
  3. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    Yes sir, absolutely. :)
  4. MSmithPDX
    MSmithPDX Member
    Portland, OR
    With a volt meter set to read DC voltage in the 10s. You also need to know what the voltage is supposed to be.
    http://tinyurl.com/pqoespm
  5. Hectorsd
    Hectorsd Member
    San Diego,California
    1970 Ford Maverick
    I think is the whole cluster instrument the problem with sender unit
  6. Jsarnold
    '72 Sprint
  7. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    anybody got a part # for the instrument voltage regulator for the 76' mav? Looked on ebay but didn't really find one...could be using wrong search criteria.
  8. rthomas771
    70-77 are all the same. It's call an INSTRUMENT CLUSTER VOLTAGE REGULATOR or IVR for short. Any Mustang Vendor has them
  9. Hectorsd
    Hectorsd Member
    1970 Ford Maverick
    I do have an extra instrument cluster for sale!!
  10. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    checked voltage today at alternator = 14.22
  11. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
  12. Craig Selvey
    Another issue you may be having is that the 1976 instrument cluster is very prone to turning to dust. If the cluster has started to "crumble away"...then you are losing some of the contacts on the back of the cluster....screwing things up.
  13. Hectorsd
    Hectorsd Member
    1970 Ford Maverick
    Hi I do have an extra instrument cluster for sale $100.00
  14. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    mine had a very small pinhole in the float it would get gas in it and not read above a 1/4 tank I changed it and it now works fine
  15. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    Okay. Pulled the cluster out today and cleaned all contact points on the circuit board by lightly sanding with 1000 grit (came clean as a new penny), then swabbed with electrical contact cleaner, then finished with LubriMatic dielectric grease. Replaced 4 bad idiot bulbs and one gauge light. Hooked it back up and pretty much the same result - key in 'run' position brought fuel gauge up to just past a 1/4 tank...then when engine is started it comes up to just past half.
    Soooo, as per the link for testing the VR I tested it on the bench and found that on the positive side it read 12.28 volts....but when I switched to the negative side it read the same, with about 1 or 2 pulses down to 11.46. So I am thinking a new VR might be in order.
    That being said, I have scoped out both the OE type and the 'solid state' type. I am assuming that the OE type will suffice...any comments?
