Fuel gauge reads empty
Discussion in 'Technical' started by David74maverick, Jun 19, 2014.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Is there a way to test if it's the fuel level sensor or the float without removing it? I just want to know if I should order a new fuel level sensor or not before I remove it... Thank you.
  2. rthomas771
    You said that it works but not accurate. Could be the instrument voltage regulator (IVR) not doing its job
  3. David74maverick
    Arizona
    I was wrong about it reading/reading wrong... I think either the sending unit or the float was going through it's final death throws... since that comment it hasn't moved except when I grounded the wires at the tank...
  4. David74maverick
    Arizona
    I was wrong about it reading/reading wrong... I think either the sending unit or the float was going through it's final death throws... since that comment it hasn't moved except when I grounded the wires at the tank... like I said I ohmed the sending unit and got a reading of 86 which is higher than the range I read about so I don't know if that means it's the sending unit is bad or simply the float/level arm is resting on the very bottom...
  5. David74maverick
    Arizona
    I'm going to be removing my fuel gauge sending unit in the next few days than it hit me... what if the o-ring is bad or gets damaged in the removal. Is there any local type shops that may have a usable replacement? if not is there a RTV silicone that could be used to make it work? I'd appreciate some input. Thank you.
  6. rthomas771
    Melvin's has the O-ring...and every Mustang supply vendor in the phone book. Part number C0AF 9276-A
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Replace the O-ring whether you think it's bad or not. It's gotta be 4- years-old.
    And no, RTV will NOT seal it. It will leak like a son of-a-gun. RTV is not made for use with gasoline anyway.
  8. David74maverick
    Arizona
    while doing some searches I found that if I removed the space and dash the number relates to a '95 or so mustang which is available locally but I can't find dimensional info on either to be sure. does anyone know anything about this?
    I've never heard of Melvin's... have you ever ordered from them? if I wanted to replace the strainer what size should I get? '74 250ci 2dr.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What "strainer"??
    I've ordered from Melvins and they are very good.
  10. David74maverick
    Arizona
    They offer both 3/8" & 5/16"
