Fuel gauge still reads empty
Discussion in 'General Maverick/Comet' started by x72COMETx, Sep 22, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    I installed a new fuel sender unit today good thing mine was nasty and it still reads empty, I'm going to pick up a volt meter tomorrow and test the wires but in the meantime does anybody have any suggestions thanks
  2. Craig Selvey
    Pull the plug off of the sender. There are two "plugs" inside of the plug. Short them together with a temporary wire and turn the key on. Should read full at the dash. If it does...wiring is fine/fuel sender is not. If it does not...you have a wiring/electrical problem and the fuel sender is probably fine.
    Hotrock likes this.
  3. jtown77
    jtown77 Member
    Arizona
    71 Comet
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    ive had my cluster out so many times its pretty easy for me now, i will check that out today thanks
  5. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    Had this problem 40 years ago.......bad ground.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    ok i tried jumping the wires at the fuel sender and got nothing at the gauge, i unplugged the wires in the trunk that go through the floor to the sending unit and nothing
  7. Craig Selvey
    You have a wiring/electrical issue I would say.
  8. Krazy Comet
    One of the wires on tank sender plug will be yellow & white, ground that wire to chassis... If it reads you have a ground issue on sender plug(black wire)...
    If there is still a problem you should find the yellow & white wire at plug near kick panel... Again ground to chassis, no reading indicates a gauge, voltage regulator(on back of cluster), circuit board issue or no power to the cluster on the Black & Lt Green wire...
