Fuel pressure requirments
Discussion in 'Technical' started by Saleen0793, Aug 3, 2017.
  1. Saleen0793
    Saleen0793 Member
    Saint Thomas Pa
    2000 Saleen SC,73 Maverick
    I had a 347 built, has 430 hp on a engine stand dyno. I am getting ready to work on fuel system, What for fuel pressure do I need to carry ? going electric . also noticed the car had a line running the trans tunnel that I guess was a return or vent tube,where would this line connect if it is even needed.
  2. 71gold
    if it's a carb, 5-7 lbs...:huh:
    Saleen0793 likes this.
  3. Saleen0793
    Saleen0793 Member
    Saint Thomas Pa
    yes it is running a carb
  4. bmcdaniel
    Sooo if it's carbed why an electric pump with all the additional filters, regulator, etc? A simple mechanical pump will fill your needs.
  5. spork1o1
    spork1o1 Member
    Michigan
    run a stock type mechanical pump with 3/8 line from tank to pump, -6 line to regulator -6 line to carb. The carb is an 850 preform out of the box settings, feeding a RPM Air gap on top of a 347. ran a best of 6.86 @ 101 mph.
  6. Saleen0793
    Saleen0793 Member
    Saint Thomas Pa
    I have no real reason to run electric, other then I have changed everything else why stop now. LOL
  7. junrai
    junrai Member
    rancho cordova ca
    if youre not running high hp I would recommend the mechanical I recently did an electric pump and DAMN is it noisy I can practically here it over my exhaust when running and its way back under the 1/4 panel. its a holley red pump
    just FYI I wouldnt recommend for a daily or street cruiser
  8. 71gold
  9. Saleen0793
    Saleen0793 Member
    Saint Thomas Pa
    I am hoping in the future to go blow through at about 10 psi
