Fuel Pump Electrical vs Mechanical
Discussion in 'Technical' started by Snoho73, Jun 28, 2026.
  1. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    My 73 302 has a mechanical, I assume stock fuel pump and I am getting 10-12 psi at the Edelbrock 1406. Before I add a regulator, was wondering should I install an electric pump. What pros/cons? Pressure regulator suggestions?
    Mike
  2. TeeEl
    TeeEl Senior Member
    Colorado
    I'd stick with mechanical, but get one that produces no more than 6psi...
  3. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Current one appears stock, how do I know output of one off the shelf?
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    A small block Ford mechanical pump should not exceed 7 psi. at maximum. Benefits of a mechanical, cost, simplicity, availability, installation\replacement. Benefits of an electrical, easy start at all engine temperatures, less drag & junk hanging off front of engine (especially if power steering), EFI ready, consistent pressure at all rpm's, possible delivery of cooler fuel.
  5. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Well that is the problem, my mechanical pump is delivering 10-12 psi at carb. I have used two gauges to check in case of a bad gauge. I have read reviews of most stock pumps and they are rated less than 6psi, but lots of users say they got more. Just confused...., this car will be a low HP restomod, so just trying to be efficient and frugal (cheap).
    Thanks
  6. TeeEl
    TeeEl Senior Member
    Colorado
    There's no way your engine will run with an Edelbrock carb at 10-12 psi. It would flood out.
    Edelbrock carbs don't like more than 5psi.
    Pressure regulators are better suited for electric fuel pumps...
  7. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Well that was my thought. New gauge reading 10-12 psi. Why I was questioning the group.
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I know I'm way late to the party on your most recent response, but glad you found out. Now, just install a fuel pressure regulator and set it to 5psi. Easy Peasey.
