fuel pump relay...
Discussion in 'Technical' started by 71gold, Apr 24, 2020.
  1. 71gold
    installing a new in tank fuel pump...
    DeatschWerks DW400 Universal In-Tank Fuel Pump - 415LPH..(9-401-1001)
    need to know
    #1- what size fuse to put inline with (16-20 amps at typical operating pressures)?
    #2- should the relay amps match the fuse?
    thanks
  2. bmcdaniel
    Frank, what AWG wire are you running?
    If you're using the correct gauge wire you pick the fuse or breaker to match the wire size.
  3. 71gold
    thanks B Mc D...I'll check and see what fuel pump fuse they used with the CV fuel pump assy. I used for my mod. (Airtex E2085E)
    ...:Handshake:...
  4. 71gold
    seems to be a 30 amp...
  5. bmcdaniel
    For a 20 amp circuit you would typically use 12 AWG and 10 AWG wire for a 30 amp circuit, if it's a constant running pump. If it's powered by a PWM controller you can get away with slightly smaller wire. The usual 30 amp relay would work in either case. Remember, fuses don't usually protect devices, they just protect the wiring when the device overloads.
  6. 71gold
    thanks...I read where a device was fried with 20 amps and never blew the 30 amp fuse.
  7. Krazy Comet
    If draw never exceeded 30A, fuse should never blow, as stated fuse protects the wiring.
    Doesn't mean pump could not lock, draw 28A, then over heat tank till gas explodes.
    At least wiring was protected. ;)
  8. 71gold
    ...:yikes:...
  9. 71gold
    blew the 10 amp fuse used with the old pump...replaced it with a 30 amp.
    ran for about 4 minutes and melted the cheap relay...have this one ordered and ready for pick up at Summit in the morning around 10 ish.
    Relay, 75 Amp, 4-Terminal, Bosch, Built-in Mounting Brackets
    PS..
    and as Tom said...it didn't blow the 30 amp fuse just melted the relay...:slap:
