Fuse for Taurus Fan?
Discussion in 'Technical' started by Jsarnold, Nov 28, 2010.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Thanks. That helps a lot.
    Maybe I'll use my Flex-a-Lite controller, since it has the AC-on function and timed run with key off, to control the low speed and control the hi speed -- alternatively with low speed -- with another temp sensor and 80A circuit.
    Don't suppose you know the switching temp for the original idiot light sensor. Probably too hot to use as the high side control.
    Or, maybe I'll do the low speed only and see if I even need the high speed. The Champion 3-row radiator seems to have outstanding cooling capacity. Sure would simplify things if I only needed the low speed.
    Lots to think about. Thanks, everyone, for describing your setup.
  2. 71gold
    that's what makes this one so simple it's all made for you.
    ...switched on12V to red wire...red/green wires to high/low fan...two wires in the middle to your sensors...
    $10 at Pull A Part...
  3. bmcdaniel
    Frank, what's the temperature settings on that part? Or is it adjustable?
  4. Jsarnold
    '72 Sprint
    I can see why you used it. I might still go that way if I can get one for $10, even though I already bought a controller. Expect they'll be at least twice that around here. I never find any deals in our junk yards. I'll see what I can find.
  5. 71gold
    get the temp sensor for the temp you want it to operate at...
    mine are...
    (1) (Low side)...on 185/ off 170...installed in intake...
    (2) (high side)...on 205/ off 185...installed in T-stat housing...
    ...:cool:...
  6. 71gold
    after i got everything installed, i bought a new...Volvo...relay for $55.
    if you go this route, get as much of the stock Volvo harness as you can. this way there will not be any splices.
    Frank
  7. Jsarnold
    '72 Sprint
    Frank,
    OK, thanks.
    My bro in Arizona DOES have a good junk yard connection. I asked him to see if they have any Volvos with the controller. Any particular year or model? All I knew to tell him is it should have 2 fans or a two speed fan. Sent your picture of the controller.
    Jim
  8. 71gold
    i got this from Jays tech article...
    '92 and up...W/E-fans.(2) ...mounted on the rad. support.
    ...:tiphat:...
    [FONT=Times New Roman, Times, serif][SIZE=+2][​IMG][/SIZE][/FONT]9442933 Cooling Fan Relay (2 speed),
  9. bmcdaniel
    I see. Does your car ever get up to 205* and turn on the high speed?
    Edit: I forgot, you have an auto trans and A/C, etc. I don't have any of that.
  10. mercgt73
    mercgt73 Member
  11. 71gold
    i got all the parts to do that but couldn't find a place to install a 22MM threaded hole...i didn't care to go the in hose route...also that sensor is a 195 low/205 high.
    ...:cool:...
  12. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Jim
    The
    Flex a Lite# 31165 is the one I tried on my Taurus fan with no long time luck. To high amp draw..
    Talked with the tech guys at flex a lite and he said that unit WILL not take that high amp. draw ( thats was after I bought it ).
  13. Jsarnold
    '72 Sprint
    Thanks for that, Mavdog. Did you run the hi speed thru that controller? I'm thinking of using it only for the low speed and doing a separate hi-amp circuit for the hi speed. Haven't sketched the wiring diagram yet but I don't think it'll be that hard to figure out. If yours didn't last running just the low speed I'll give up on that controller.:mad: I'd like to use it (since I bought it) to turn on the low speed with the AC.
    Wish junk yard parts weren't so expensive around here. I called the one I usually go to (about 20 miles away) and they wouldn't/couldn't even tell me if they had a Volvo in the yard. "Should be one here" was all I could get from them. That's why I prefer new parts if I can get them. Used to really enjoy a junk yard crawl but not so much anymore.
    Jim
  14. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Jim
    How soon due need a volvo controler ???????????
    Because I need to go to the junk yard and get some for a friend he want 2 of them .
    I will not be able to go untill after the hollidays.
    Jay
  15. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Jim
    On the flex a lite I used both low / high speed as well a/c side
    Jay
