has anyone changed their fuse panal to the new blade type fuses? if so where can i get the panal. i called today and found a universal tube type as a replacement, but i would like to do the blade type if i can. thanks...frank...
SOunds like a pretty custom job. I don't see why you wouldn't be able to find a newer style fuse block in a junkyard that and find a way to custom wire it into your fuse panel. However, is it really worth the work? Fuse panels are usually out of sight out of mind type of things.
