Gages in dash
Discussion in 'Technical' started by maverick306, Apr 18, 2013.
  1. mojo
    I recall the guy who had the fiberglass design who passed. I think he has a relative who also is a member of this forum; I believe he finished the one his dad was working on -- just don't remember all details of who it was.
    Anyway, great attention to detail on the dash as well as the rest of the build Glen. I wud imagine it was a time consuming project getting all those angles right an coming out w/ a very symmetrical looking part. You have some real talent in the fabrication spectrum. :thumbs2:
  2. Moneymaker 1
    Panama City Florida
  3. Jellob1afra
    Jellob1afra Member
    San Pedro, california
    1971 mercury comet
    what kind of audio set up do you have and what kind of layout? i like this idea
  4. 55crownvic
    55crownvic Member
    colorado springs
    I did on my maverick, used a piece of exhaust pipe, and used 3m panel bond to "glue" them into the dash on the right side of the ash tray, Will look for a pic to show you.
  5. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Glenn,
    Have you checked the clearance behind your panel? When I put the 5" Autometer MCX gauges in my factory cluster I had to do some cutting on the wiper bracket. Your setup may not be that deep, but it may be worth checking...
  7. ptpdub
    ptpdub Member
    canada Sk.
    It is nothing fancy, I just ran power from my battery (fused it there) through my firewall (gromit) under my carpet under my back seat into the trunk. then it splits off (distribution block) to 2 amps. one runs 6x9s in the package tray, and the other to a 10 inch sub in box. i run ground from both amps to the steel in the floor of the trunk (grounded, then sealed and painted both top and bottom) a signal wire from both amps to switched power. i ran rca's from a headphone jack adapter, under the carpet into one amp and then from that amp (internal crossed over) into another amp. everything comes up out of the ashtray for a clean look. i coil the wire up in the ash tray when i want to make it go away, and poof! no stereo in this car!!
  8. Mavaholic
    I made a flat panel.
  9. car-nut
    car-nut Glenn
    conn.
    Thank you for the concern, seriously. When I made the panel I left the wiper motor assembly in the car, as well as anything else that might get in the way. I have plenty of room. Although, I know the 5" gauges you have are deeper, so maybe I wouldn't then.
    Thanks,
    Glenn
  10. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I REALLY dig that, did you cut that in, or just add it on top of the contour and cut holes for the wires to pass through?
  11. mrskydog
    Muskegon MI
    iola_2010_reunion_lacrosse_057_original.jpg gauge_install_001_original.jpg I made some I posted about a year ago simple ,made to fit in center vent cage. Made out of PCV tube, looks ok.
  12. Mavaholic
    It is cut into the dash. Here is another angle.
    [​IMG][/URL][/IMG]
  13. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Cool that looks real slick.
    Man this thread is a goldmine of ideas.
  14. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    guage panel
    I made this out of some sheet metal. Did ok..I guess
