Garage heat
Discussion in 'Tool & Shop Talk' started by plynch, Dec 8, 2021.
  1. plynch
    plynch Member
    New Hampshire
    '72 Maverick
    For those in colder climates these next 5 or so months, I'm curious as to what you use to heat your garages? I've got a 2 stall and I doubt any options from Lowes are gonna get the job done.
  2. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    have a gas heater on the wall.
  3. Powerband
    Powerband Member
    NY's \H/
    "I'm curious as to what you use to heat your garages?"
    My unattached but insulated 2 bay has an oil fired hot air heater . Common around here to use a (used ) hot air Mobile Home (Miller ) type or other small home oil/gas fired hot air unit. Electric is simpler install but typically burns $ ... . Wood heat is option. Mostly depends on fuel source. (Local building codes should be a considered.)
    Thermostat keeps garage just above freezing in coldest weather or can warm it up for work in a half hour. In coldest weather timer warms it up for me in AM and once overnite.
    [​IMG] . . [​IMG]
    .[​IMG]
    have fun
    plynch likes this.
  4. Fastkarz
    Fastkarz Member
    Northern NJ
    1972 Maverick Grabber 347/AOD/4.11
    We have natural gas so I use a 70,000 BTU forced air unit hung from the ceiling to heat the 1480 sq' garage. I set the tstat at 55 all winter and turn it up to 65 when I am out there working. I have a few ceiling fans on low that I use to move the air around. The garage is 2x6 construction with insulated doors, R19 in the walls and roof, tyvek wrapped with 1/2" foam board and 1/2" insulated siding. Seems like the heater only comes on when i open a door. Stoping the air leaks is key
    BBMS18, plynch, mojo and 1 other person like this.
  5. plynch
    plynch Member
    New Hampshire
    '72 Maverick
    I should've mentioned I do have a wall-mounted propane heater in the above garage space/loft running to the tank outside. It's a detached so I'm tempted to tap into it for the garage area, but I'm also planning on finishing that space above and put in a mini split for heat/cooling. i could run another unit downstairs. Of course, none of it's currently insulated, so that should be step 1. Thanks guys!
  6. Craig Selvey
    Also depends on if you want heat on all the time, or just when you want to work on something.
    plynch likes this.
  7. Fastkarz
    Fastkarz Member
    Northern NJ
    In North NJ I leave the heat on 24/7 at 55F. Then the tools and cars arent frozen and its a comfortable work environment. With the heat on constant it barely runs as long as you arent opening doors.
    plynch likes this.
  8. bmcdaniel
    bmcdaniel Senile Member
    Natural gas heater in my uninsulated 2-car garage. Don't remember if it's 20k or 30k BTU but it gets stupid hot in no time. It's probably too big for my little garage but I got it at a yard sale for $75.
    plynch and 71gold like this.
  9. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    I live on acreage in a rural area have lots of wood on property, woodstove in shop is awesome!
    plynch likes this.
  10. 71gold
    that with an oil drip tube makes the wood last longer and get rid of used oil...win/win.
    Russell and plynch like this.
