Gas caps
Discussion in 'Cosmetic' started by TM74, Nov 23, 2016.
  1. TM74
    TM74 Member
    Buffalo, NY
    1975 Grabber
    What years do the gas caps change?
    Like the knobby one was 1970-71, the horned one was 1972-? And which year did the "MAVERICK" script on the cap start, 75 or 76?
    Thanks.
  2. Craig Selvey
    The design on the front carried over many different years.
    The back is what is different. The amount of "ears" (2 or 4) and how they are "clocked" and the depth of the ears is what matters.
    TM74 likes this.
  3. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    1972 Mercury Comet, 1980 Chevy Malibu, 1987 Chevy R10
    Sorry to bring up an old thread, but I have a 2 "ears" cap on my comet, Will a 4 "ears" work? Are they interchangeable?
  4. 71gold
    it will work if you swap the tank spout also...:yup:
  5. Craig Selvey
    As 71gold stated....it will work if you swap gas tank necks. Otherwise, my answer that you quoted above is still accurate.
  6. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    Thank you for the clarification. (y)
  7. rthomas771
    Correct me if I'm wrong, but isn't all Maverick filler necks all clocked the same? I had in my hand every Maverick filler neck except the '77 neck and only difference I seen was the length of the neck going into the tank...not counting the leaded/unleaded differences with the opening for the gas pump nozzle and flap door. I do know the Comet filler neck has a different bolt pattern than a Maverick and some year Comet necks could come with a different cap clocking. I also notice the ears on the Maverick caps are clocked different (but not the filler necks).
  8. Craig Selvey
    The differences I have seen across all years is (this list does not include the differences between Comet and Maverick):
    1. How far out the "neck" sticks out past the rear tail panel. This affects how far the gas cap sticks out away from the tail panel
    2. The "notches" in the gas filler neck to allow the "ears" of the gas cap to be inserted. Just a slight difference in size and maybe placement I seem to recall.
    3. When installing the cap, how far you can twist the cap around before it stops. This will affect the "clocking" appearance of the cap.
  9. Craig Selvey
    Here is the Maverick and Comet gas filler neck differences. Notice the bolt locations as well as the "notches" for the gas cap ears.
    Russell likes this.
  10. Craig Selvey
    Look at the differences here as far as how far out the gas filler neck sticks out past the tail panel. The filler neck with the red paint does not stick out as far. The other one is off of a 1973. It is a not a big distance/difference.
  11. 71gold
    these seem to be the same flange but mounted on the spout at a different location...
  12. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I have both caps for my Comet. I use the 2 prong one and when I get to the car shows I put the 4 prong cap on it. It was a NOS one still in the box. They both fit and are clocked the same.
  13. rthomas771
    I used the early deluxe cap that came with the bailing wire on the '75 unleaded filler neck and the 76 locking cap on the same unleaded filler neck. They both fit and are clocked the same also.
