gas filter clogged? oil is gas tank!!!
Discussion in 'Technical' started by duster70, May 15, 2006.
  1. duster70
    duster70 Member
    Houston, TX
    1970 Maverick I-6 automatic
    this must be one of the stupidest things yall have heard, but dont blame me. I was home one day and my mav had no gas since ive never filled it up. I went to the backyard and saw a little gas container. I looked at it, opened and pured some out. Smelled like gas alright! thats what i thought:mad: I put it into the gar, it was about a gallon or less and you know the car started. The next day i turned on the car and after a while it just sputtered and died. When i pushed the gas evenn a little it turned off. I put in another three gallons of gas, and it still sputtered and died. My dad then told that the gas container I got (the one taht had less than a gallon) had gas mixed with oil!!!!!!!:mad: he and my uncle told me that the gas filter had probably clogged up with oil. What do I do??? Can it be that the filter is clogged and is it easy to change it? should I have a mechanic do it? is it easy???? thanks!!!!!
  2. maverick75
    the filter is really easy to change and cost less than 3 dollars(should be on the carb)
    i'm guessing that gas/oil mixture was ment for a weedwacker or lawnmower
    also some fuel pumps have a filter and their is another filter in the gas tank(fuel sender)
    carb fuel filter
    fuel pump filter
    gas tank filter
  3. Jamie Miles
    I put 2 stroke gas in my car once and didn't notice any diffrence in the way it ran. I have a hard time believeing the oil in the gas is your problem, especially as dilluted as it is now.
  4. don graham
    my neighbor had an el camino that the fuel pump went out on. he was towing a small boat. they got the outboard motor gas tank that was mixed with oil and ran the hose into the carburetor and drove the car with 1 guy pumping all the way home. i think it was about 60 miles and it didn't hurt it. i'd try to change the filter. it may have been on the verge of needing to be changed anyway.:)
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Oil in the gas?
    Someone here accidently put diesel in their car once. Maybe they can tell you where to look for a clog.
    :dance:
    :eek:
    :biglaugh:
    :evilsmile
    :drive:
    :29:
    :rofl2:
    :yikes:
    :bouncy:
    :D
    I'll forget about that someday! Sorry, Dan.
    Seth
  6. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I agree with Jamie....There is more than likely something other than a little oil in your gas. If your car seldom sees a full tank, your problem is probably a dirty fuel system (have the tank,lines flushed and filter(s) changed
  7. Jamie Miles
    Man, what an instant classic that thread was. :rofl2: :biglaugh: Going back now and rereading it, I can't help but start laughing when I read where Dan starts questioning why his brand new engine runs the same as his messed up old one did. But then he figgures out it was Diesel after he put a new engine in the car. Dennis goes "Damn Dan, I dont think I can say anything to make you feel better, but at least the problem is solved." it brings a tear to my eye. :biglaugh:
    I remember when he was talking about selling the '74 to buy a new engine for the Grabber. It definatey wouldn't have been so funny then. :(
  8. baddad457
    X3 (y). The oil in the gas mixture will not be caugth by any filter I know of. Both your Dad and Uncle are wrong:16suspect
  9. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    2 an a half year old thread,, not sure if new member just a newbie or spam
  10. Acornridgeman
    Wisconsin
    Definately spam ... :yup:
    say goodbye to the spammer! (y)
