Gas fumes
Discussion in 'General Maverick/Comet' started by William623, Aug 8, 2022.
  1. CaptainComet
    no worries here. I was having fun with your reply.
  2. William623
    Orlando
    1973 ford maverick grabber
    I think I am going to take out the AN line and replace it with steel or aluminum and then use true vapors guard on the connecting pieces. I’ll used AN fittings to tie it all together.
  3. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I didn't even see your original post about it all being the AN line. I assume that is the steel braided but with a rubber jacket? You can get PTFE lined hose from many places (I got mine from https://hotrodfuelhose.com/) and that would definitely make a massive difference. Hard line is also good, but if you already have the clamps in place and don't want to bend new lines, a PTFE-lined hose may be a good option. Unfortunately each PTFE hose takes specific hose ends, so you won't be able to re-use any.
    William623 likes this.
  4. William623
    Orlando
    Thanks! I think I’ll go ahead and swap the lines. They seem to have good pricing.
  5. William623
    Orlando
    Finally got around to making the lines. PTFE lines worked great. No more gas fumes! They are a pain to work with but well worth it.
    xpsnake and TeeEl like this.
  6. xpsnake
    xpsnake Bruce
    That's great!
