Gas tank Capacity Question
Discussion in 'Technical' started by rap43, Aug 22, 2003.
  1. rap43
    rap43 Member
    Phoenix, AZ
    74 Maverick 4 door, 73 Maverick 4 door, 76 Maverick 2 door
    Craig - How can I tell for sure that the engine light is due to low oil pressure? The engine light comes on and stays on after the engine has been running for about 10 minutes. The car is not loosing any oil, it is clean and the engine temp stays within the normal range for being in 110 degrees. What can be done to correct low oil pressure? Could it also be a vacum leak in the carb?
    Does anyone have a 1976 owners manual that says anything about the engine light ? (other than it saying to take it in to your local Ford dealer).
  2. Craig Selvey
    You could put am engine oil guage on it....that will tell you the story.
    Grabber_73 likes this.
  3. Mavrick newb
    Mavrick newb 20 Year old Mavrick fan
    Central Point, OR
    1973 Mav 351w 76 Mav 302
    When he said O2 sensor I just assumed he had new 5.0 in there lol
  4. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    In my Chilton's manual, it lists the Fuel Tank capacities as follows for all models (2 and 4 door):
    1970: 16 Gals
    1971: 15 Gals
    1972: 15 Gals
    1973: 15 Gals
    1974: 15 Gals
    1975: 16 Gals
    1976: 19.2 Gals
    1977: 16 Gals
    Hope this helps you out some.
    -Corbin
  5. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    In later Mavericks, the 'Engine' light was connected to both the coolant temp sensor AND the oil pressure sensor...a cost cutting measure, I guess instead of having separate lights like the earlier ones...so...the problem could possibly be low oil pressure or high coolant temperature....
  6. rap43
    rap43 Member
    Phoenix, AZ
    The engine light coming on was due to the water temp. I was at a buddy's house today and we tested the anti freeze for strenght and the water looked like mud! We flushed the raditator 3 times and put in fresh anti freeze and it runs alot cooler (no engine light now!)
    I was also having a problem with my A/C not staying on and when I giggled the wiring harness the compressor would kick on and off. Took the hole thing out and tighened up connection to the switch and that workds good now too. That whole unit is a PAIN to get out through the front!!
