Gas Tank
Discussion in 'Technical' started by Shoestring, Apr 10, 2006.
  1. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    I'm looking for a new Gas Tank, and I came across this:
    http://www.1aauto.com/1A/GasTanks/Ford/VanFullSize/F15D/8310
    I'm wondering if it'll fit my 1974 Maverick? I'm only looking at that one 'cause I'll be able to spend that much. I can't find a Maverick Gas Tank off google, anyone know where to find one?
  2. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    This website says '75-80 so I think they're confused. The only difference is between the '70-'72 and the '73 and later models right? I know it's more than you wanted to spend, but I think $60 is worth the headache of getting something else to fit.
    http://www.gastanks.com/prodinfo.asp?number=F-30
  3. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    Nice. Thanks a lot, ATO! :)
  4. Mavaholic
    From what I have seen the 74 tank was the same as the 71-73. In 75 they went to the larger tank. I dont know if it changed in mid year or not but I have yet to see anything but the small tanks in a 74. You can bolt the 75 tank in there but they require the longer straps and the way the vent is, might not be the same as yours. If not you can buy the vent set up from Ford still. Just check my Gas Tank Mod on this websight for the part numbers. Another difference would be your sending unit. It will bolt in but it may not be deep enough to suck out the last few gallons. Lastly, it will rub against you rear valance panel along the very bottom if you have a 71-73. 74's wont have this problem.
  5. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    Thanks a lot, Mavaholic. I'll be sure to check it out. Thanks again.
    EDIT: Hmmmm.... Can't seem to find you Gas Tank mod, Mavaolic, :rofl: Mind telling me where it might be? ... I'm just stupid and can't find it!
  6. mercgt73
    mercgt73 Member
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i did that mod to mine. pretty easy to do.
  8. 71gold
    i said it will fit a 75-80 granada...does this mean that year granada tank will interchange with a mav./comet? :huh: ...frank...:bouncy:
  9. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    Merc, thanks for the link. I forgot all about that page. I'll let y'all know how it goes, just have to get the extra money for all this stuff. Never fails. Once I get the extra funds, I need it for something else.
    Thanks again, guys!
