Gasket sealant on crab gasket?
Discussion in 'General Maverick/Comet' started by mrcomet, Aug 18, 2024.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Good morning everyone,
    I am changing out the carb gasket on the Comet. First time doing this. Was wondering if you should, or should not, use some black gasket sealant on the intake or the bottom of the carb when installing the gasket?
    What have you all done..................
    Thanks!
  2. BruceS
    BruceS Member
    Texas
    1973 Comet
    No sealer
    rickyracer, mojo and Ronald Hopkins like this.
  3. TeeEl
    TeeEl Senior Member
    Colorado
    Nope...
  4. 71gold
    nope..
  5. satchelmcqueen
    satchelmcqueen Member
    north georgia
  6. bmcdaniel
    Those crab gaskets work pretty good without sealer. Now lobster gaskets on the other hand...
  7. Krazy Comet
    Luke on Thunderhead289 coats his carb gaskets with chassis grease. I've seen him pull off gaskets that had been in use four or five years, then reuse them.
  8. CaptainComet
    I was going to suggest this .... LOL
    Seriously, if a dry gasket doesn't seal the carb to the intake, start looking at pitting of the intake surface or make sure it is flat. I had a corroded carb spacer that made one car run terrible until it warmed up.
