Gear Oil suggestions?
Discussion in 'Technical' started by Acedmav75, Nov 21, 2014.
  1. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Im rebuilding my differential and was wondering what you guys recommend for an 8inch with 3.55 gears. Thanks.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If it's a limited-slip differential, use Valvoline 85w-140, and use a limited-slip additive.
  3. 71gold
    use what the manufacturer of the gears suggest...:yup:
  4. tody
    tody Member
    cologne, germany
    use a gl5 spec oil.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    break it in with any good mineral based gear oil(of proper viscosity) with friction modifier.. and then swap over to a full synthetic with a friction modifier mentioned above.
    With the heat that the car will see down there.. you're gears will thank you for the extra cash spent on synthetic. Even get slight improvements in mileage too if you're into that sort of thing.
    Acedmav75 likes this.
