Gilmer Belt Set Ups
Discussion in 'Technical' started by mav1970, Aug 20, 2009.
  1. baddad457
    The slippage & belt throwing reference was in the Ebay auction someone linked to. Nothing wrong with doing it for looks.
  2. mav1970
    Thanks for the pictures. :)
    The main reason, that I asked about anyone using a Gilmer set up, was that I am also looking for something more visual than using a standard V belt set up. Since I'm using a front engine plate, which pushes the water pump out towards the radiator a half an inch, I'll wind up having to use a half inch machined spacer on the crank to put everything back in alignment, no matter what set up I decide on. The alternator, I can move forward with brackets.
    The "Getto" comment I felt wasn't worth responding to. :huh:
  3. Mavman72
    Found the other source for Gilmer belt drive set ups...
    Millerspeed; Hermosa beach,CA; (310) 408-8798
    They have a wbsite: millerspeed.com but its under construction so...not alot of info on it yet.They set ups for all sorts of engines/configurations and bracketry as well.
  4. Dave B
    I'd be worried the belt was going to walk itself off one of the pulleys...but maybe not since it's so thick?
  5. falcain
    falcain Member
    Toledo, Ohio
    1970 Maverick, 66 Fairlane, 89 Mustang LX Convertible
    The setup I am running has a raised collar on both sides of the alternator pulley that keeps the belt from walking.
  6. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    very nice engine bay in the fairlane !!!! way cool !!!!
  7. falcain
    falcain Member
    Toledo, Ohio
    Thank you. Hopefully, I can get the Maverick to look like that some day. I'm afraid I have a little work ahead of me. :)
  8. maverick5.0
    maverick5.0 Member
    if it looks like the one in the fairlane it will shure be a knock-out !!!!good luck...-mel-
  9. bmcdaniel
    Sorry to drag up an old thread (well, not really)...
    Does the hub/bolts of the gilmer water pump pulley sit farther forward than the stock pulley hub/bolts? I only have about 1/2" clearance now between the pulley bolts and my electric fan.
