giving in to the 302
Discussion in 'General Maverick/Comet' started by maverick656, Sep 10, 2014.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    So I'm giving in, I want to swap my 250i6 with a 302 (makes a little more sense as I'm not wealthy haha) how much and how hard is it to find a nice 302 that doesn't need rebuilt as soon as I get it? And as for everything else, I wanna put a T5 in It with it. How much roughly does it cost to swap the engines (including everything that you have to modify) and do the transmission swap from a c4? Mines a 75 4 door maverick 250i6
  2. 71gold
    4-6K
  3. Craig Selvey
    I would suggest you take baby steps. First...lets get the V-8 in there. You can probably find a decent used motor, and all the parts necessary to do the swap...for around $1000. The T-5 is going to be harder to do and more expensive as well.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You can do it pretty cheap if you hunt for the deals and aren't afraid to kill a vehicle for what you want from it. What are your plans for the 302, stock or modified? If you plan on staying stock you can pick up the T-5 from a V-6 Mustang cheap compared to the V8s and the late model units are comparable in strength to the Fox V8 transmissions. One of those would live a good long time behind a stock 302. It will take the larger flywheel which you can get from a full size truck. So far I am into my setup dirt cheap, I bought a rolled 94 Bronco for $300 that had 90k on the engine which ran great, scrapped the body and sold as much of the rest as I could and ended up $300 ahead in the end and my dad still got the new tires! I picked up the T-5 from a wrecked 98 Mustang with a V-6 for $150 with under 65k on it, I'll still pull it down and inspect it but the fluid was clean and everything feels smooth. I still need to get the flywheel and clutch as well as a hydraulic set up to actuate it all but that is way down the road.
  5. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Well my plans are for a mild street rod. Nothing that's gonna be running 10's or even drag racing for that matter. I just want something with a little more power, and from what I've seen and doNE research on, I'm gonna be spending a pretty penny on hopping up my i6. And with that money could have put a v8 in it. Would the C4 be able to handle the 302 well? I don't want to be blowing out my transmission if I can help it. And from my understanding the rear end gears will need to be changed?
  6. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Your c4 will be OK behind a mild 302, if it has a lot of miles on it I would recommend a rebuild with a shift kit. Regearing is not necessary, but is the best performance boost for the cost.
