Glove box door warped
Discussion in 'Cosmetic' started by fullcm, Aug 25, 2017.
  1. fullcm
    fullcm Doug
    Michigan
    74 maverick
    My box door is warped. Was going to try to bend it back into shape but realized its not metal. I'm thinking even if I were to find another blue one it may likely have the same issue.
    Has anyone had any luck straightening one?
  2. Mavman72
    You could try clamping it to your level there so its straight and pouring HOT water on it...Immediately followed by COLD water...Outside of that...Not gonna have much luck getting it to come back. You could always scrounge up a straight one and paint it to match...Good luck...
    Russell likes this.
  3. 71gold
    I straightened an instrument bezel by placing washers under each end and clamping it. the washers caused the bezel to clamp past center. I left it in the sun all day then let it cool over night. it came within a few thousandths of being straight.
    jasonwthompson likes this.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I was going to recommend clamping it to something straight and then placing it in sun, but as I have never tried it I refrained.
  5. 71gold
    that's how you find out if it works. you suggest it to someone and let them try it...:huh:
    LOL
  6. junrai
    junrai Member
    rancho cordova ca
    I was thinking clamp it straight and let it sit in the sun if that doesnt work the water trick might. theres really no going wrong its already bent so you cant hurt it
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    I think I may have a couple of these laying around the shop somewhere . If I find them , I'll check it for 'straight' and I'll get back to you if you' re interested. Lemmeno.
    Cometized
    ( Chip )
