going to make a cowl hood this weekend
Discussion in 'Cosmetic' started by sam03rc, May 29, 2010.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    here is the pic of the hood before i started to weld on the top there is enough room for my 14x4 in k&n air cleaner and have about 2in all the way around
  2. sam03rc
    sam03rc Member
    gates county, nc
    yea i cleaned it up a bit around the edges it was cut into the bracing by someone else it came with my parts car when i bought it but it seems to be fine doesnt flex or anything so im guessing its fine
  3. blugene
    Looks like it had hood pin holes too.
  4. sam03rc
    sam03rc Member
    gates county, nc
    yea it did the parts car was used for drag racing but i welded them up so they are gone
  5. blugene
    Nice work. :)
    So did you lay the cut out on top and weld it then feather the edges?
  6. sam03rc
    sam03rc Member
    gates county, nc
    yes the about front half lied flat and when i welded it in it took very little body work just to smooth it out and the back half had to re bend the side to give the height i wanted while trying to match the original lines then glassed it and then bondo over it to smooth it out
  7. blugene
    I will be working with a glass scoop so it will be a little different. Welding it on seems like would be the better way, but not what I will be doing. I'll be feathering tho lol.
  8. sam03rc
    sam03rc Member
    gates county, nc
    yea then youll have to use glass and get a good base line then bondo to smooth it out the rest of the way. just a tip like ive been taught to sand it down with 60-80grit first to give the glass something to grip to to last longer
  9. blugene
    lol I was thinking about 40 grit :).
  10. sam03rc
    sam03rc Member
    gates county, nc
    yea rougher the better. the more tooth there to grip the better
  11. blugene
    Sickening how you newbees are progressing faster than me lol. jk:D
    I WILL be working on my car next week dangit! :burnout:
  12. 71gold
    what did the underside of the "cowl" look like? did it still have the brace on it when it was welded on or was it just the "skin"?
    Frank
  13. indyman13
    indyman13 Member
    Little Rock, Arkansas
    This is great watching fab work progress and hearing the stories. Pretty neat what can be done with a little thinking, nice parts materials and a well thought out approach. My hat's off to all of you. (y)
  14. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    the grabber scoops openings are pretty small,so an opening at the back of the hood help alot.
  15. sam03rc
    sam03rc Member
    gates county, nc
    its just the skin on the cowl top section. i was thinking something would need to be on there to hold it stiff but when i cut it out it just separated from the bracing. then when i put it on the hood and bent it then clamped it in place and it was pretty stiff the only place that flexes is the far back lip
