Gonna swap the trans this weekend. How to clean it up and prep it?
Discussion in 'Transmissions' started by scooper77515, Sep 1, 2009.
  1. Mavman72
    Scott...I allways toss the nylon gaskets and weld the outer nut to the pan.:thumbs2:
  2. scooper77515
    That pan is steel, so I will weld that crap in myself!
  3. Mavman72
    Just remember to leave the plug in the nut when you do it...Or you may never get the plug in it afterwards.
  4. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I have a deep sump aluminum pan with a drain and a threaded hole for a temp sensor. This thing. I'm quite fond of it. Last time I had to put a temp gauge on a transmission I ended up using a T and compression fittings, couldn't make it stop leaking.
  5. blugene
    I like that! Where does the sensor go?
  6. scooper77515
    Where's the temp sensor?
  7. facelessnumber
    Memphis, TN
    '71 Grabber
    It's on the right side of the pan. Comes with a plug, but the sensor for a B&M electric temp gauge threads right in.
  8. facelessnumber
    Memphis, TN
    '71 Grabber
    By the way, if anybody decides to buy that pan based on what I've said about it, you might want to call BTE or the seller first and make sure it's got that temp sensor fitting. The pic on the website doesn't show the side it's on, and it looks like it might be slightly different than mine. You can see it on the transmissions they sell though...
