Good sounding cam
Discussion in 'Technical' started by scott, Nov 14, 2004.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I was going to try to use the stock ones until I rebuild the motor. One day, I do want a 5 speed or 6 speed when the money is right.
  2. igo1090
    igo1090 Member
    catonsville, md
    2500 stall shouldnt be a problem on the street depending what rpm you cruise at and your trans cooling system. put an external cooler on just to be safe.
  3. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    That's what I thought too. And some more rearend gear like a 3.73 of 3.80
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    So what cam would you guys recommend I put in? I am looking at putting in 3.55s after wrestling season and getting the heads ported a bit when I can hold down a job in about february.
    -Todd:)
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't mean to sound like a jerk or anything... but you would get better response to your questions if you posted your own threads.
    I notice that you tend to hi-jack other threads, I have done it a time or two, but it's not really good to do it all the time.
    Dave
  6. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    the 351w and the HO's have the same fireing order it was a custom grind cam they have a cam number but the specs can change ..thats what they said ..and for close to $400 bucks hope so
  7. scott
    scott Member
    new jersey
    No hard feelings man, i just want ot know what cam would be best for me with a decently noticeable lope.
    -Todd:):)
  8. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Well scott, If the pistons are stock, I would not go above .500 or .520 in lift. Evan this might be to much but I don't know for sure. The XE268 is just slightly above the .500 mark but it works. This is just what I think. Like others say, You can't hace a cam that shakes the car without braking something if the engine is stock.
  9. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I'm sorry my fellow members. This is the first & only forum I belong to. Ratio411 thanks for not being a jerk, I didn't know any better. I'm still learning. Sorry Scott also. You guys please forgive me. I have to learn how to post my own threads.
  10. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    No biggie. At least it was a relatively on topic hijack. Talking about heads, springs, piston to valve clearance, lift, stalls needed with certain cams etc. I think the original thread starter benefited from the conversation. If you would have popped in with "hey guys, what size wheel can I fit on my car?" it may have been different :)
    AC
  11. stockhatch
    '72 Grabber
    Scott, I think you will be sorely dissappointed if you get a Competition 268 and expect lope, but thats just me. If you were running a roller motor, I would strongly recommend the B-303 cam. It has a CRAZY choppy idle and a moderate lift. Down the road, if you want more lift, toss some 1.7s on the car and have a decent cam. The B-303 cam gets along very well with stock springs and piston to valve clearance is a non-issue. I honestly dont know of a flat tappet cam with comparable specs so I cant recommend one. The others on here who have actually run some of the more aggressive flat tappet grinds will steer you right though.
    AC
  12. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Scott, Ford Racing has their own cams on the web site. Some are roller & some are not. I didn't see to many that seems to be very aggressive. But like Stockhatch said, with a 1.7 rocker they could be better.
  13. scott
    scott Member
    new jersey
    now if i can just get todd to post under his own name instead of mine.....
  14. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
  15. bmcdaniel
    a decently noticeable lope...
    Why don't ya just pull one or two plug wires off? :D
