Got a new welder...
Discussion in 'Tool & Shop Talk' started by scooper77515, Jun 19, 2006.
  1. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Not to hijack your thread but I recently purchased a new welder and am extremely happy with it....it's a Miller Syncrowave 200, TIG welder......makes for some EXCELLENT beads!!
  2. scooper77515
    Man, that is a BEAUTIFUL bead...
    What exactly is a TIG? I have heard all the different names thrown around, but don't know TIG. Is it gas assisted? I ask because if I added gas to my wirefeed "MIG" and it looked like that, I would definetly start buying bottles.
    Your welder is WAY uptown compared to mine.
    But, again, I paid $115 for mine.
    I did go a little out and buy one of those newfangled auto darkening hood...
  3. igo1090
    igo1090 Member
    catonsville, md
    gas mig will look somewhat like that depending on the welders skill and material being welded. mine usually start to look like that about the time i am finishing up the project. dont get enough practice, and sometimes its 6 months between welding jobs.
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    :rofl2: You appear..... different!
    Good news on the .035", I'll try that myself. Thx
  5. scooper77515
    Yeah, I let my hair go... :D
    I used to be able to get a weld looking like that with an arc welder on stainless, but with this wirefeed, it spits and spatters and needs to be ground down to a decent looking weld afterwards. I just weld until there is too much material laid down, then grind it down to a nice looking bead.
    But, that is only if it is a visible weld, like on the top of my shock tower cuts. Underneath, I just knocked the slag off and paint over it.
    I am going out daily and just tinkering with the welder settings and materials being welded on, and using the spray, just trying to get a nice looking weld with the cheap MIG.
  6. CometGT1974
    Western NC
    74 Comet GT
    TIG welding (also known as GMAW or Heliarc) is very similar to gas (acetylene)sp welding, except it uses electricity to create the heat instead of gas. It's an expensive way to weld but it makes for the best looking, strongest beads of any form of welding. Also, you can basically weld anything with it....aluminum, stainless, titanium, copper, bronze, etc...
  7. CometGT1974
    Western NC
    74 Comet GT
    oops....TIG is GTAW and MIG is GMAW.......or "Gas Tungsten Arc Welding" vs. "Gas Metal Arc Welding"
    Or to make it even more confusing TIG = Tungsten Inert Gas vs. MIG = Metal Inert Gas.
    You will get much better welds on your MIG machine if you switch it over to gas.
  8. Mexmaverick
    Mexmaverick Member
    Coahuila Mexico
    Maverick 1975
    Floor pan
    Hi, Some body knows what type of sheet metal is better, to repair the
    floor pan of my Mav.
    Thanks
  9. blugene
    I bought some at Home Depot, but it is kinda thin. I'm not cuting anything out i'm going to weld it to the facing on the inside, of the rear foot area.
    Comet GT1974 is right, I added gas to my Lincoln 100 HD and what a difference.
  10. Mexmaverick
    Mexmaverick Member
    Coahuila Mexico
    Maverick 1975
    what tickness have the piece? is stainless steel or what , or how can I buyed
  11. rolandag2
    rolandag2 Member
    Dickinson, TX
    1970 Maverick Grabber
    new welder
    I just bought a new 140amp wire feed with gas and let me tell you it welds beautiful on the sheet metal of any maverick. man it works great:29: ;)
  12. rolandag2
    rolandag2 Member
    Dickinson, TX
    hey if try the 23 wire and get gas it will clean up the weld beautifully.
  13. scooper77515
    I am not sure if I can add gas to this welder, it is too cheap...
    Unless someone knows a way to do it. It has the larger 1" diameter plastic hose surrounding the wire feed unit, so maybe I can rig up gas to feed into it?
    If not, I will use this for a while until I burn it up then buy a Lincoln that will accept gas. As cheap as this one is, I will be amazed if it lasts more than a year.
  14. scooper77515
    Also, what is "23 wire"? I may PM you in case you don't read this often.
