Governor/modulator questions
Discussion in 'Transmissions' started by russellgaspard, Aug 11, 2016.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I've been having transmission problems and was told it was the governor that was the problem. My car has this governor http://www.rockauto.com/en/moreinfo.php?pk=45221&cc=1132175&jnid=482&jpid=7
    It has two vacuum hoses going from the governor to the intake. Are they both supposed to go to the same vacuum port? It doesn't make sense that they both hookup to the same port.
  2. mav man
    mav man Member
    wi
    70mav
    That's a oddball one all of mine had the nipple on the end just single one and were adjustable in side of nipple
  3. Krazy Comet
    Dismal Swamp
    That's not a governor, it's a modulator valve... The governor is inside the tail housing...
    71gold likes this.
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    That's a 73 only modulator, I don't remember how its connected, but I've been told the single vacuum green strip is the one you want.
    71gold likes this.
  5. russellgaspard
    united states
    Well the guy said my problem could be from either of those parts. The governor or the modulator. When I start to accelerate the transmission doesn't slip but it will get to a high rpm before shifting. This basically goes for every gear. It isn't on any particular gear that it does this. Was what I told accurate? Or is it something else? I was told this by a mechanic but I want to make sure
  6. russellgaspard
    united states
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
  8. russellgaspard
    united states
  9. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    The thing that holds it in the transmission.
  10. russellgaspard
    united states
    Oh alright. The one I have on there currently doeset have one but I'll try to find one for that modulator
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    What you describe sounds like the modulator, governors rarely fail. I had a GM transmission that the vac hose fell off and it would hold 1st and freewheel when you let of the throttle. They do wierd stuff when they fail!
    russellgaspard likes this.
  12. russellgaspard
    united states
    Thank you everyone! I found the green modulator on amazon for $16 by looking up the part number! I hope this works to fix it!!
  13. russellgaspard
    united states
    Also you said it's adjustable so what is the adjustment for? Also how do I adjust it properly?
  14. RMiller
    Kennewick, WA
    There is a screw inside the nipple the hose goes on, it changes the spring preload and therefore the amount of vacuum it takes to move the piston. Unless you are needing to fine tune shift characteristics I would just leave it as is.
  15. mav man
    mav man Member
    wi
    70mav
    It's basically adjusting how fast or slow it up shifts from 1-2&2-drive when you're not on the throttle that hard
