Grabber highback bucket seat buttons
Discussion in 'General Maverick/Comet' started by fmc56, Feb 10, 2008.
  1. Dave B
    I stripped a 74 bucket seat, from what I could tell, the frame is really close to the Mustang, but the seat foam is molded around the frame, it's not a cushion like the 71-73 Mustang, and if I remember right, there is a difference in the springs on the bottom frame. If some of this snow melts I'll get out to the shed and take some pictures of them. Sorry for the hi-jack.
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    This is great stuff, guys.
    It is amazing how many reproduction parts have been put in the works for these cars over the past 2 years. It's all because of the increasing values of these cars.
    Thanks to those with the ability to push the projects through, and the folks assisting them with info and original/NOS parts for reference.
    Seth
  3. fmc56
    fmc56 Member
    Warwick,RI
    1977 Maverick, 1932 Ford Victoria, 1965 Econoline pickup, 1963 Falcon Deluxe Club Wagon, 1963 Falcon Sprint, 1971 SC-360 Hornet, 1972 Gremlin X
    I am doing a complete set of front bucket and rear covers for a 73/74 Grabber right now. The cost is about the same since they use the same amount and type of material and same amount of labor. The Ruffino grain vinyl is the heavily textured vinyl used in the seat inserts. the smoother grain used on the rest of the seat and door panels is Corinthian grain. An optional woven vinyl, sometimes referred to as Comfortweave was also used as an insert material. I will try to photograph some samples.
    Fred
  4. fmc56
    fmc56 Member
    Warwick,RI
    I spoke with a rep from a major reproduction seat trim cover manufacturer today about reproducing the 71-72 highback covers. They already produce the 71 Mustang covers so they have the patterns and all of the necessary vinyls to do the Maverick ones. There are only some minor differences. I will be meeting with them at the end of April and should have an answer shortly afterwards. If all works out they will be in production by June and available through any of their current dealers.
    Fred
  5. rayzorsharp
    That sounds fantastic Fred! There are a lot of us in need for this!
    Thanks
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That is awesome Fred!
  7. fmc56
    fmc56 Member
    Warwick,RI
    update
    I met with the national sales rep for the seat cover company. They looked at the covers I had made and see no problem in doing the 71/72 Maverick/Comet highback covers. We decided against heat sealing the buttons to the vinyl as the originals ones were done. Instead we are going to make an exact copy of the vinyl button in plastic with the same finish. They will attach with two tabs through the cover like most other seats. It will look identical to the original. The covers are made one at a time when ordered so that mass producing the heat sealed buttons won't work out, more cost effective too. This will also allow using them on a bench seat or any custom applications. Most colors should be available since they are used on Mustangs. The comfort weave will be the reproduction embossed type. If anyone wants the real comfort weave I can still make those. A run of app 200 buttons will be done. I have not been given a firm delivery date on them yet. I do not have a pattern for the rear seat but if I can supply them with one they will also make the rear covers.
    I have also completed a full set of covers for the 73/74 highback bucket seat interior. Most likely they will also go into production.
    Fred
  8. CaptainComet
    This is awesome news.
    Thanks for the update. I hope to be ready for set in the coming months.
  9. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    I would like a set of 71-72 med. ginger covers. How much would that run? Thanks!
