Grabber hood repair..Where to cut.
Discussion in 'Cosmetic' started by RobertBailey, Aug 14, 2007.
  1. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    I am waiting for my tool and rust encapulator from eastwood to arrive. I check all the auto supplys places around town, at least the ones that will sell to non-business types, and nobody had anything. I ordered this one
    http://www.eastwoodco.com/jump.jsp?itemID=10466&itemType=PRODUCT
    I got the donor sub-frame marked and cut, then I used a pair of tile snips to peel the skin off. did ok but let some ripple around on top. I just peeled the sides and whacked the back with a rubber mallet and it slid out. when the tool arrives then I will start on the grabber hood.
    Robert
  2. Craig Selvey
    Let us know how the tool works out.
  3. RobertBailey
    Should be here tomorrow, If it does arrive I will start on the grabber hood tomorrow after i get home from work. I'll take some close-up pics of before and after of an area so you can see how it works.
    Robert
  4. RobertBailey
    It was setting on the door step when I got home, :dancing: I had dinner then went to work on the grabber hood, I cut the framing a little long then drilled out the spot welds then started peeling the fold back with the new tool. WELL I think It was worth the 30 bucks(y). Works a hell of a lot better than the tile snips....I started on the sides and in about 10 mins I had both sides peeled back. After you do the first pass, you go back to the start an put a little more back angle on it and the lip will stand up close to 90 deg. The top side didn't get rippled either. Didn't get it all done, stopped at 9 . just have to knock it out of the back side. Just hope I have it cut right.
    Here is a couple of pictures.
    Robert
  5. Craig Selvey
    Thanks Robert for the update and the pix.
  6. RobertBailey
    went to whack the back frame like i did the donor, just a little lazy get the sides up then lift up on it a whack the back with a rubber mallet and this is what happened, and the guy said it was a good hood. Bondo hidding everywhere, doesn't matter but though it was worth a post.
    Robert
  7. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Robert I might be missing it but isn't this the grabber hood? You cutting this frame out anyways to replace with a good section? Is the skin still in good shape?
  8. RobertBailey
    yep, removing the rear section of the grabber and replaceing it with a good one that came off a flat hood. the flat hood's front section , you can stick half your hand through. finding some filler on some parts of the skin, but it is worth fixing. I have 4 grabber hoods and this one needs a rear section and the other needs a front. I have 2 yards that had a good flat hood that looked as if someone had stood in the middle but it was fairly rust free, need to go get it. Plus I have 2 good flat hoods in the garage to, but they are too good to cut up.
    Robert
  9. RobertBailey
    here is pics of the other problem areas. :cry:
    guess I will be learning body work at the school of hard knocks...beating, sanding and welding;)
    The black areas are where the frame was setting, I painted it with eastwood rust encapsulator after hitting it with a scotch brite wheel to knock off all the loose stuff.
    as you can see there is a lot of pitting, mostly in the corners. Looks like I will be getting a crash course in body work.
    Robert
  10. Rando76
    Rando76 Member
    Claremore, OK
    Wow - this is a great thread. I've got a Grabber hood that I need to something similar too. Except that I've got damage on the top as well.
  11. Maverick Dan
    Maverick Dan Member
    Greenbrier, AR
    72 2 dr Mav, 74 Comet, restoring
    You guy's are killing me. I can't find a Grabber hood to buy in any condition....
  12. Mavaholic
    Excellent work so far!!!
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    This is my favorite thread!!!!
    Dan
  14. RobertBailey
    Well I am commited..other that the crazy part:biglaugh:. I have cut the back corners off the donor hood and the grabber hood. I was thinking about using the butt weld tools from harbor freight, but they seem to leave a big gap between each side. I might try the magnets to see if I can get them closer.
    These hoods were not manufactured to a tight tolenence. I measured 3 different hoods and i got 51 3/8, 51 1/2 and 51 3/4 from the bottom of the front to the back corner. same thing going across the rear, got difference measurments
    I can tell you I am getting real nervous about this. I haven't done much body work and no welding on this thin of metal. I picked up some .023 wire for my welder, but it doesn't feed very well. I did a little practice on some thin stuff I had laying around and kept blowing through. So I created a copper spoon out of 3/4 copper pipe to use on the back side, which helped quite a bit. I am going to get me a tig next month.
    Robert
  15. Dan Starnes
    West Central IL
    Robert,, I use magnets in doing butt welds all the time,, remember, in a case like this, you have adjusments to allow for in welding up this hood. I agree with a small space in your welds to allow for penetration, especially on the back side. I got faith in you dude.
    Dan
