Grabber rear spoiler mounting hardware
Discussion in 'Cosmetic' started by BBMS18, Mar 23, 2019.
  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Hello fellow Maverick & Comet lovers, it seams that a lot of the Grabber spoilers have lost there mounting hardware after being removed from the car. In this thread I will show you what I used to make these pieces for my friend using my factory pieces as a template.
    First let’s start with pictures of the factory pieces with some measurements.
    A7C2F947-EE79-4CEC-B59E-06790E4142C6.jpeg 212B7271-047F-4EE9-8CB4-EC3643C94B7A.jpeg CE151900-0E4D-4F20-BCF1-83D5ACAD9E30.jpeg A2ADA956-502D-4CDD-B0F5-00EA22055495.jpeg
    I stopped by the local Menards and found these “Steel EMT Conduit Cap’s” part #41582 for $2.09 each. You will need 4 of them to mount the spoiler, although I suggest getting 5 (things happen).
    5BF829CD-242A-4FF1-8F83-73E0646EC92D.jpeg F51D722C-004A-44A3-9BEA-D48CC0D1B2D3.jpeg
    I apologize for not having a picture of the 3/8 hole I drilled in the center of the cap. But I think you get the idea.
    I cut them to length (1.25”) and marked two sides for the openings (0.664”) then cut them out using a cutoff tool.
    One of the cuts should remove the piece that has the holes for the screws.
    Clean them up with a small grinder and bend the ends so it looks like this finished part.
    Now all you have to do is paint & mount the spoiler.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Nice job!
    BBMS18 likes this.
  3. yellow75
    Tillamook Oregon
    Great job , I have made them out of pvc couplings but I like this method better
    BBMS18 likes this.
  4. RMiller
    Kennewick, WA
    The big question I have is how long did you wander the isles of the hardware store before you found the caps? I can spend 45 minutes or more roaming the isles with an idea before I spot the appropriate solution.
    BBMS18 likes this.
  5. BBMS18
    BBMS18 Member
    75 Comet
    I would say 20 minutes, it sometimes takes me longer than that when I know what I’m looking for.
    RMiller likes this.
  6. mercgt73
    mercgt73 Member
  7. BBMS18
    BBMS18 Member
    75 Comet
  8. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    a fine job .
    i may be making some more comin up soon, i know ive said that before..
    BBMS18 likes this.
