Grabber scoop
Discussion in 'General Maverick/Comet' started by 73curtis, Apr 16, 2016.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Those drilled holes look really good. I wonder exactly what was used to drill them.
    I had a set of scoops that I had a friend completely cut out. I then epoxy'd some mesh grill material that looked just like the fake grill pattern. Then.........I lost them. I have no idea where they could have gone. 'Really bums me out. How do you lose a pair of Grabber scoops??
    In any case, I think I'd rather have them drilled like those shown here.
  2. 71Mavrk
    71Mavrk Member
    Nevada
    No problems with the big sticker on my car.
    Micah
  3. Paul Masson
    1971 Grabber
    image.jpeg image.jpeg image.jpeg Mine are factory fresh. Original paint.
    FIREBALL likes this.
  4. 73curtis
    73curtis Member
    ohio
    howeve
    is that really factory original paint , never repainted?
  5. Paul Masson
    1971 Grabber
    Yes, @73curtis , my car still has the original paint on it, except the lower cowl and engine compartment. The car has a little over 20,000 original miles on it right now.
  6. 73curtis
    73curtis Member
    ohio
    Is the black a decal , I have seen some with double stripes did they change from year to year or Was it always one solid stripe ? Is your car all back together yet ?
  7. Moneymaker 1
    Panama City Florida
    Large decals can be intimidating, I designed, cut and applied my own, this is heavy 3-M reflective vinyl, lots of soapy water when applying and don't use transfer tape (decal will slide easily to position) or you can use transfer tape but leave it on till it's dry, pulling the transfer tape off too soon will cause bubbles, just use a good squeegee and any small bubbles that are left after you finish can be taken out with a straight pin/needle, I applied mine by myself, didn't take long at all once I got going with them, was really freaked out about it before I started, once I got going it was all good! you can see they came out nice and smooth.........
    Paul Masson likes this.
  8. Paul Masson
    1971 Grabber
    1970 Grabbers had two stripes painted on the hood and cowl.
    1971 Grabbers had one large area painted on the hood only (like mine). This is why a STENCIL is all that is available through Licensed Ford products.
    1972 Grabbers had two large vinyl decals separated by a small relief of body colour.
    My black treatment on my hood and tail panel has a slight texture to it and NOT gloss.
    My car is not back together yet. It still needs the following:
    • Vinyl top needs gluing
    • Seats need installing
    • Front and back glass needs installed
    • front fenders, hood, grille and bumpers need to be installed
  9. 71Mavrk
    71Mavrk Member
    Nevada
    Stripes were painted on in '70 and '71. Both did not have a center stripe but '70 stripes went into the cowl. '72 had the center stripe.
    My car is a '71 with '72 stripes because I ran into the same problem, not possible to clear over it and have it remain flat as original. They do not make a '71 decal unless you have it custom made. I like the center stripe.
    http://mmb.maverick.to/threads/72-grabber-stripes-gloss-or-matte-black.103346/#post-1051100
    http://mmb.maverick.to/threads/71-grabber-stripes-original-layout.97348/#post-994812
    Micah
    I see Paul was typing the same thing at the same time :p
  10. Paul Masson
    1971 Grabber
    I'm pretty sure 1970 had two separate stripes on the hood, though.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    Paul,
    I stand corrected.
    Micah
  12. 73curtis
    73curtis Member
    ohio
    Does anyone have a photo of a 72 hood? What year is the blue car and are those stripes original style
  13. spxer
    spxer Member
    Raleigh NC
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I didn't know that the '70 stripe went over the cowl. I always thought people who had it over the cowl were doing it wrong.
    'Always learning.
  15. Craig Selvey
    I call that a "weekend" at my place. LOL
