Granada Disc Brakes
Discussion in 'Technical' started by Mavman94, Dec 22, 2014.
  1. 73curtis
    73curtis Member
    ohio
    does it feel like a normal brake pedal height
  2. 73curtis
    73curtis Member
    ohio
    the way mine is now i have to pick my leg up to hit the pedal, way to high
  3. Krazy Comet
    Dismal Swamp
    How bout taking a pedal measurement???
    A manual pedal is generally a 1-1½" higher than a power brake pedal... Got a orig drum brake Comet out back I'll measure to see if there is a difference...
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It will be the SAME height as your drum brake setup was.
    You haven't swapped that rod out yet???
  5. Krazy Comet
    Dismal Swamp
    Actually it's not, my '72 with orig rod, new carpet & '74 disc/drum MC measures 7 9/16" from carpet to bottom of pad, while the '71 with it's beat down carpet measures 7 1/4"... I've been thinking it was just a illusion but '72 no doubt sets higher...
    I"m probably going to add one of those hot rod mini boosters that have been mentioned, though for grins I may shortening the rod a little first... The '71 will be my guinea pig for the booster project...
  6. 73curtis
    73curtis Member
    ohio
  7. 73curtis
    73curtis Member
    ohio
    do you think the adjustable rod will work to lower the pedal
  8. Krazy Comet
    Dismal Swamp
    As long as it can be adjusted shorter than orig no doubt, but that brings up a question...
    Apparently the std rod is 6" measured from TIP to CENTER of the pedal mounting opening, the adj rods I've seen say adj 6" to 6½, so may require shortening, assuming that's possible...
  9. 73curtis
    73curtis Member
    ohio
    what do you mean by standard,do they make different lengths for power or non power or drum and disk different? Just wonder if you have seen the different length ones?
  10. 73curtis
    73curtis Member
    ohio
    if adjustable one doesnt work i will shorten it,just hope it doesnt interfere with brake light switch, dont remember how that is mounted
  11. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Just a few days ago i dealt with this problem. I ended up cutting a little more than a 1/4 inch from the middle of the rod, Threading both parts of the rod, and used 2 jam nuts and a coupling nut to make an adjustable push rod. if you have the tap set its an easy fab. it ended up looking almost identical to this (plus one jam nut)...
    to be clear, the pic above is from a universal kit i found online to use as an example of what my adjustable rod looks like.
    Krazy Comet likes this.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    From My experience, it is.
  13. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    That's great, that's what i did in the past (over 20years ago) but i now suffer from C.R.S and had a brain fart......but any way-that's originally what i wanted to do , but if you read my earlier post when i changed the old master out for the disc brake one I used the new rod and now cant get it out. I tried pressing it out but instead of the clip breaking it felt like if i put any more pressure on it it was going to snap the ears on the new master off....i tried something similar to Moneymaker 1 figuring the quick pull instead of the steady pressure might be better but that didn't work either; so after trying these ideas is when i came up with the adjustable rod idea...i dont have a welder like a few others here that cut theirs and welded back together and i'm too cheap/dont have the disposable funds to buy another master or i guess i can just live with it for now or I'll try the fork idea to separate it.
  14. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    PErfect!! thats what im going to try THANKS.
  15. mojo
    Trying to figure out how the setup works compared to the top picture? The one thing escaping is how is going to be attached to the brake pedal? I assume the U shape bracket is what's intended to attach there? It appears the hole in that bracket is much smaller than it needs to be to attach to brake pedal?
