Grandpa and grandson maverick project
Discussion in 'New Members Forum' started by Shedrick, Aug 16, 2021.
  1. Shedrick
    Shedrick Member
    Albuquerque
    1972 ford maverick
    Hello newbie here Have a 1972 ford maverick with a i6 with a250 and c4. Plan on swapping ford 5.0l and trans out of a 92 lincoln mk2.been reading a couple articles on the swap and to know if anyone has tried the swap recently and would like to share the info. Thanks in advance
    BBMS18 likes this.
  2. 71gold
  3. Hotrock
    Munroe Falls, Ohio
    Krazy Comet likes this.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    Very cool...
  5. DGD
    DGD Member
    IND
    Welcome another’s ‘72! Good luck and God’s speed.
  6. mav1970
    :Welcome: from Northeastern Pennsylvania
    Shedrick likes this.
  7. bmcdaniel
    :Welcome: from south central Pennsylvania
  8. Hippylong
    Hippylong Hippylong
    72 maverick, 64 dart gt v8 4spd,65 barracuda S v8 4spd
    I am doing a 302 aod swap from a 250 i6
    C4 setup. I also have a 72.
    Russell and Shedrick like this.
  9. Krazy Comet
    Mark-VII AOD are slightly longer than Stang & T-Bird units, probably require shortening drive shaft.
    Also if considering fuel inj, the orig wiring harness incorporates ABS & air bag suspension. In total, harness is about 25-30ft long.. Routing is from ABS unit down driver side fender apron, across radiator support and back up right fender apron. At that point, a portion feeds across firewall to the salt & pepper shakers(engine harness connectors).. Remainder feeds EFI computer in right footwell, on to trunk area where ABS & suspension computers are located.
    No, even I'm not brave enough to tackle one of those. Luckily the Turbo Coupes have two mostly separate harnesses. I used a 5.0 Bird engine harness when I installed the MK-VII 5.0 into my Turbo Coupe.
  10. Shedrick
    Shedrick Member
    Albuquerque
    1972 ford maverick
    Thanks for the info. I know of the extra wires and extra systems but not scared of a little wiring in to days age of cars. I work on them for living now for 18 years now master for 14 years now.im not saying I'm a experts by any means. Not planning on using the other systems just ran across a deal on the car I couldn't let go. Looking at pulling apart mkii this winter after I put fuel pump in it to figer out problems before i pull it apart Might I ask what turbo set up you used on your project.
  11. Shedrick
    Shedrick Member
    Albuquerque
    1972 ford maverick
    What doner car you using?
  12. Shedrick
    Shedrick Member
    Albuquerque
    1972 ford maverick
  13. Krazy Comet
    I should have said ex Turbo Coupe, sold the half motor & turbo. No wait, the turbo went on another T-Coupe that had blown the turbo.
    The 5.0 made power via Trick Flow - Twisted Wedge heads, cam & 8-10 other Hi-Po goodies.
