Great Article on Mike Bowen's Coyote Stock Maverik
Discussion in 'Drag Racing' started by olerodder, Apr 24, 2014.
  1. 71gold
    so if you had a...stock Mustang with a "Coyote" motor, you would have to replace it with a..."sealed spec crate motor from Ford"...:huh:
  2. groberts101
    groberts101 Member
    Minneapolis, MN
  3. olerodder
    olerodder Member
    NorCal
    When I raced with the SCCA, I raced with a "Spec" Miata. The engines were also were also "sealed", but there were a few things that could be done to motor before it was assembled and sealed(no balancing, port matching, lightening, or any visible machine marks on the heads etc., but what a few builders do is to take 10 motors, disassemble them, then find the closest matching weight rods, pistons, pins etc.....which is almost the same as balancing a motor), and it had to be a certified engine builder.....cert'd by the SCCA........Rebello Racing Engines is a local one here in Northern California, and held National titles with some of their Spec Miata engines.
    I would assume these motors have a little more attention to detail than a standard assembly line motor,.........I would think anyway, because although they have a steel crank and rods, the pistons are not forged.
    A lot of cars in this class use the older Fox Body cars and I believe this will be the only Maverick running in the class..........which is kind of neat!
  4. 71gold
    I think it would be neater to see the Mav. on the road and the motor in a Pinto...:tiphat:
  5. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    So does this mean you don't like the idea of putting a late model Ford engine in a Maverick ? :huh:
  6. olerodder
    olerodder Member
    NorCal
    Since it is pretty much stock I would think the Maverick can be driven on the road because it has an exhaust system and is pretty much stock, with exception of a few items......................"Race on Saturday, and drive it home on Sunday".
  7. Krazy Comet
    Dismal Swamp
    I don't much like the overly complicated, fat ass Coyote/modular in anything, would just as soon have the late Chevy that's a drop in...
  8. Dave B
    A Coyote isn't complicated, look into it. Its the way of the future. I've been doing some research, and it seems that a number of people run AJE suspensions, on the street, with no issues.
  9. M.A.V.
    Macon,Georgia
    To each his own...but putting an LS in a Maverick requires the same mods to the car as the Coyote does, so a "Drop in" it ain't.
  10. 71gold
    nope...just don't like the idea of making a "big wheel motor stand" out of a Maverick...:D
  11. olerodder
    olerodder Member
    NorCal
    So Buddy, does that mean after all we gone through you don't like me and the "Big Wheel" Maverick??????????
  12. 71gold
    nope...just the "idea"...:D
  13. Dave B
    I don't see what the difference is? I'd be happy with 412 HP outta the box.
  14. 71gold
    difference is...it's a drag motor, not a street car...:yup:
  15. Ian164
    Ian164 Member
    Nova Scotia canada
    1976 comet gt
    I like the idea of the coyote in the car it's diffrent. Plus it's a big motor good hp what else could you ask for. And the coyote is a very tuneable and easly wired engine in any application. Race it get ice cream in it do a burnout
