GREAT day!!! Carb is better and scored X 2!!!
Discussion in 'General Maverick/Comet' started by scooper77515, Feb 29, 2008.
  1. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I didn't call anybody an ostrich. Anna posted this picture of an ostrich, just from the top of the legs down, wearing short pants, argyle socks, and house slippers. I'm curious as to how someone got all that on an ostrich and have it stand still for a picture. :huh::huh:
  2. scooper77515
    It is a stuffed ostrich, not alive anymore. Got it on a hunting trip in Montana a couple years back.
  3. scooper77515
    Cool!!!
    Got the 9" home, it is off an old 289/302 bronco. Not sure which year. Measures 53-1/4"...only 1" wider per side than stock:bananaman
    I think I will leave the length alone and just buy different rim backspacing from now on...
  4. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    GOOD SCORE!!! Most likely a 1966-1977 Those rear ends around here are worth big $$$
    And on a side note my uncle works at at drivetrain shop,they have a digital balancer and only charge $50 for a balance.He told me alot of the time a driveshaft flings a weight off or got dropped at some point and is generally a easy fix.
  5. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Just move the spring perches and you're good to go. I have a Bronco 9".
  6. scooper77515
    Where can I get axles for this?
  7. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    You can find Bronco axles on e-bay. Just look for the '66-'77 model years. The bolt pattern for wheels is 5x5. If you use the Bronco axles, you'll need to drill out a 5x4.5 pattern or have one set of wheels for the rear and a different set for the back.
    If you follow Mavaholic's tech article and use the axle shafts from an 8", you can use the axles from an 8" rear.
    Of course, you can order custom ones with the right bolt pattern, length, and the spline that you want.
  8. scooper77515
    Cool, I will keep an eye out for those!
  9. Derek 5oComet
  10. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
