I think I have a ground issue. When you get a chance, would you mind checking to see if there is a body ground coming off of each turn signal in the grille? My wires were cut when I got it.
Just an up date, I was able to get the light working properly. The housing on the turn signal (grille)was not grounded, so each front turn signal/parking light needed a separate ground. The pig tail coming out of the housing had three wires each, one for chasis ground the other two where spliced into the origial harnes using an earlier style pig tail that I found at Auozone.
