grrr 1 stuck tie rod
Discussion in 'General Maverick/Comet' started by Wilsond3010, May 11, 2013.
  1. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    ok so i need some advice.
    I've tried using the pitman puller and it's not working.
    I think it's the tie rod that connects the pitman arm to the steering box
    Shows as part 3304
  2. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    take the nut off, flip it upside down, place a block on it, and hit with the hammer. Make sure the bolt is flat to the nut. So put a few threads into it. Knock it with a hammer until pops. Also may need to jack the tire up to releave some pressure/binding due to the weight.
  3. 71gold
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    are you talking about pulling the drag link off the arm?.. or the arm off the box?.. or both?
    either way.. heat on the arm ends itself(within reason) usually always makes matters easier.
  5. mav1970
    Pickle fork also works for removing inner and outer tie rod ends ( all tapered ) - pitman arm puller is only for removing the pitman arm from the steering box sector shaft :tiphat:
  6. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    Thanks got a different tie rod puller and it did the job.
    Now I can start looking at putting it back together. And then more stupid questions to follow
    like why do i have bag of bolts and rubber bushing left lol
  7. mav1970
    10 years ago, I changed the head on my son's Eclipse.. He asked me why we had bolts left over and I told him "you know you did the job right when there are parts left over" - he was puzzled to say the least :cry:
  8. CaptainComet
    You didn't use enough bags.
  9. 71gold
    I can have parts left over from changing spark plugs...:yup:
