GT40 Valve Train
Discussion in 'General Maverick/Comet' started by Joebug, Jun 3, 2010.
  1. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    Stock is 1.6ratio these are the cobra 1.7 I will get pics when I get home
  2. Joebug
    Joebug Dude with a Maverick
    Hudson Valley,New York
    1971 Maverick V8 2dr coupe
    I dont need the rockers after all, the guy I am getting the heads from has a set for me! You should PM svthauln and snatch them up... :yup:
  3. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    LOL I will stand next in line after svthauln shoot me a pm if he is not interested(y)
  4. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    I was going to buy them just to hold on to. If somebody else has a use for them go for it. If nobody comes forward I'll take them.
  5. Joebug
    Ok I just picked up my GT40 Heads and 1.7 ratio cobra rockers.... now I need to select a cam... the springs on the heads are rated for a max lift of .500 .... I dont want anything radical just something that will idle good and give lots of low end torque....
    What are you guys running that is similar to what I described?
    Thanks for any info
  6. PaulS
    Look at the Performer plus cam from Edelbrock. It has a smooth idle and will pull into the 5500 rpm range. The specs are like:
    duration (SAE) 204 Int / 214 Ex
    LSA 110 degrees.
    This cam has a longer exhaust duration to help compensate for the small exhaust port of the Ford heads. It give a smooth idle with a bunch more torque on the low end and a moderate but higher hp throughout the entire range.
  7. Joebug
    Ok I'll take a look at the edlbrock, any others that might work? Keep in mind I have to keep the lift under 500 WITH the 1.7 ratio rockers... Thanks
  8. maverick75
    Most manufactures will state the lift specs with the stock 1.6 rockers. So be sure to note that when your cam shopping.
  9. Joebug
