gt40p header fix for mave
Discussion in 'Technical' started by Jap901, Jan 22, 2005.
  1. scooper77515
    This resurrection post has pics that I posted post-resurrection (they did not exist until I did my project and after the original post was made) plus this new one from a recent roundup picture.
    This is the kind of information that I (and other P head users) may be VERY interested in...:thumbs2:
  2. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    i think roush 200 heads are set up the same way for spark plugs, real big pain in the ass on the drivers side.
  3. scooper77515
    Gotta watch which heads you buy nowadays...some have plug access, some dont. Makes a heck of a time if they dont have clear access...
  4. v8maverick
    v8maverick Member
    Delaware
    1973 Maverick, 1972 Grabber
    That would be my car, the headers are Tri-y by FPA and they are not cheap http://www.fordpowertrain.com/opening.htm , the passenger side is a drop in but the driver side I had to modify two tubes because of the pitman arm hitting them ,also had to lightly dent one pipe that was hitting the steering box. After doing the install I learned that P stands for Pain, but that's what makes it a challenge. My next project is to intall this EFI manifold.
  5. blugene
    Saweet!!
  6. scooper77515
    COOL!!!
    Thanks for the heads up on the headers....but "$435-500"???
  7. v8maverick
    v8maverick Member
    Delaware
    They have gone up in price , I paid around $375 a couple of years ago. I wonder if the driver side header would have needed no modifications if I had did a rack and pinion conversion?
  8. signal20
    signal20 Paul VanSteen
    Spring Hill, FL
    Would the explorer headers fit or at least be close? They are very diff from mustang headers.
  9. v8maverick
    v8maverick Member
    Delaware
    Usually the exhaust manifolds or headers for the 5.0 engines swing out alot further and would hit the shock towers on older mustangs and Mavericks. Another alternate choice would be to use Mustang hi-po cast iron exhaust manifolds, they don't flow as good as headers but they fit great.
  10. codycr6
    codycr6 Member
    headers
    I will be using a P headed engine in my wife's Maverick... I do have a pair of the HiPo manifolds from my 1964 Fairlane, but I don't know if they are the same. The car will be a floor shifted 4r70W, and we don't mind trimming back the shock towers some for header clearance. We are seriously looking at going single turbo like one of the Mustangs I am currently building... all five of my current Mavericks are six cylinder bodies, so I don't have anything to measure off of for working the build out. I'll stick a dummy block in when we get closer to assembly... but what would be my most obvious choices, given I don't mind trimming my towers? I can also get a spare set of header flanges if need be...
    Cody
  11. scooper77515
    RE-RE-Reresurrected!!!:rofl:
    I was starting to miss this thread!:D
    Just skip the P heads and go with non-P GT40s, or something aluminum.
    The fact that this thread has been resurrected several times, with only a $450 header to fix it, shows that they are a major hassle to work with.
    But, good luck. Sounds like you have a really interesting project in the works:thumbs2:
    And, now that I re-re-reread the post, those were the guys I was talking to several years ago when I first got my Ps.
  12. codycr6
    codycr6 Member
    engine
    The engine is out of my personal Explorer... it was hit and totaled a little over a year ago. I know the engine is perfect for what I am doing, just have header issues for the Maverick only.
  13. v8maverick
    v8maverick Member
    Delaware
    The 64 Hipo's will work or most any of the stock cast exhaust manifolds on the P heads,a mustang 2 1/4" H pipe for hipo manifolds will work if you cut 1" out (flange end) and reweld it or it will hit the firewall. If you want to use headers I have to agree with Scooper, go with regular GT40's and not P heads.
  14. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    Jmo
    screw those gt40p heads, who wants that much problem with spark plugs?
    69 mustang heads, basicly C9 heads, will out flow and out perform those silly P heads;)
  15. codycr6
    codycr6 Member
