gt40p headers ??
Discussion in 'Parts Interchange' started by shawns70mav, Sep 6, 2016.
  1. shawns70mav
    shawns70mav Member
    toledo ohio
    1972 comet gt
    has anyone tried JBA1650S-2 headers i read several articles,didnt want to spen 400.00 dollars and they dont work thanks 1972 comet gt 302 gt40p heads
  2. Krazy Comet
    From length and angle of rearward tubes, I'll say chances fitting Mav/Comet are zero & none...
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I would hate to change plugs on that setup.
  4. shawns70mav
    shawns70mav Member
    toledo ohio
    1972 comet gt
    they are shorty headers made for 66 to 73 mustang with gt40p heads
  5. Somefreetime
    Somefreetime Member
    Maverick
    im going to put them on my 1973 ford 5,0 roller going in with gt 40 p heads, the chassis is the same on the front as the 1970 ford mustang.
  6. Somefreetime
    Somefreetime Member
    Maverick
    has anyone done this with these headers?
  7. Krazy Comet
    Yep it is, but it's also something like 2.5" narrower... You can install a 390 or 428 in a '70 stang, won't begin to fit a Maverick...
    jasonwthompson, rotorr22 and mojo like this.
  8. 71gold
    I have never found any Mustang headers that fit a Mav/Comet.
  9. Somefreetime
    Somefreetime Member
    Maverick
    Is there any that will fit my maverick 5,0 with the gt40 p heads
  10. Somefreetime
    Somefreetime Member
    Maverick
    Are there any that wI'll fit my 1973 ford maverick 5.0 with gt40 p heads?
  11. 71gold
    they will all fit the engine just not the body (the outlet runs into the firewall).
    I took a set of shorties and added a 3"dia collector tube... check the bolt pattern.
    install an adapter plate to correct the bolt pattern.
    this was on my AFR headed 93' 5.0 (347).
  12. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Search "headers for gt40 p" in the search box in the upper right hand corner of the page for some good info.
    :scratchchin:
    MD
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    And then be prepared for sandwiched/doubled up gaskets, shorty spark plugs, and/or more expensive spark plug wires with heavier insulated boots. From everyone installing them into this chassis and just about everything I've read, they're not worth the extra hassle when the swap to GT40's can make life so much simpler without a loss in performance.
  14. Maverick Dude
    Yes, with the GT 40P heads the spark plug is below and to the right of the exhaust port. On the driver's side, the headers run exactly over top the spark plugs. On the passenger side, no problem, because the headers run towards the left, totally away from the spark plugs.
    :slap:
    MD
  15. shawns70mav
    shawns70mav Member
    toledo ohio
    1972 comet gt
    the header flanges worked only needed it on the drivers side with shorty plugs
