Gt40Pheads
Discussion in 'Technical' started by Campmaverick, May 13, 2022.
  1. Campmaverick
    Campmaverick Member
    Reedley ca
    1972 Maverick grabber
    Yeah I gave up on those GT 40 P heads got me a set of Edelbrock heads
    Fastkarz, Maverick Dude and BruceS like this.
  2. BruceS
    BruceS Member
    Texas
    1973 Comet
    Good job. You will be glad you did.
  3. bmcdaniel
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Yeah, it's more money, but unless the whole car is on on a very tight budget (which happens) the extra money from modern, aftermarket heads is well spent. By the time you buy and do full rebuild/upgrade on a set of factory heads the cost of aftermarket, aluminum heads with screw in studs, new valves & valve springs, etc. is closer than you think.
    For some reason only partly attributable too shock towers, Ford's otherwise excellent engines mostly had substandard ports in the heads. Even the Cleveland heads had exhaust ports not nearly as good as the intakes and tend to run hardest with a dose of extra exhaust duration.
