Guages for 75 ford maverick 4.1 v6
Discussion in 'Parts Interchange' started by Alex87tn, Apr 26, 2020.
  1. Alex87tn
    Alex87tn Member
    Tennessee
    1975 ford maverick
    Where is the best place to find a fuel gauge and speedometer? Both don’t work at all. Also what all will I need?
  2. Krazy Comet
    Welcome.
    Rather than just throwing parts at problems, troubleshooting should be first course of action. In some years the plastic housing deteriorates causing poor electrical connections. Assuming the dash lights operate, blinkers flash etc, gauge problem is likely in the tank. Resistance checks are in order, if you don't have a volt/ohm meter get one. Cheap at harbor freight. Next spend a little time learning to use it, lots of info on net.
    Speedos rarely fail, check for disconnected or maybe broken cable.
    Craig Selvey likes this.
  3. Alex87tn
    Alex87tn Member
    Tennessee
    1975 ford maverick
    The dash light do work and only the right blinker light inside works
  4. mojo
    You may have burnt out bulb. Pulling the gauge cluster and inspecting bulbs and copper circuit will probably give you an idea of the problem. If/when pulled, replace all bulbs, a lot of folks paint the inside of the housing "white" too increase visibility.
