Half my engine is not firing... I'm stumped
Discussion in 'Technical' started by Dan Greenbaum, Jul 6, 2005.
  1. 74merc
    74merc computer nerd
    1974 Comet
    Holley 600 single line with the fuel line going between the two fuel bowls right? PCV vacuum port is on the passenger side near the rear. never pulled enough vacuum on mine tho.
    When I swapped to the 4100, no PCV port, I used a one inch spacer, drilled and tapped a 3/8 pipe fitting in there. Works quite well.
  2. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Sorry, my mistake. If you look at your picture at about 2 oclock inside the circle you'll see the little nipple for the choke I was talking about. I think it lets air into the choke housing.
    I did'nt lean forward enough to look at the picture the first time.
    clint
  3. DeadBolt
    DeadBolt New Member
    Oregon
    79 ford wrecker 400, 79 ford ambulance 460, 73 ford 250 ranger camper special 360
    Just saved me on a 79' Ford 400 with performer intake manifold. Pull my edelbrock carb in the morning and fix... was thinking ignition,,, just not fuel... Thanks for the save! Dual plane takes the win.
  4. Acornridgeman
    Wisconsin
    Old thread ........ but glad a "google" search led you here for the fix!
    Welcome to the forum ........... :cheers:
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Yep, old thread but I couldn't resist. Had a guy come in for air hoses during blow out season last year, he had a tow behind compressor powered by a 4 cylinder 302. It was a 302 with one bank powering the unit and the other pumping the air. Most bizarre thing I had seen but it ran like a champ!
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    Thanks for that.. now my brain hurts from trying to figure out how that's even possible. :dizzy:
    EFI/carb feeding manifold tied only to 4 cylinders? Then the other side has a free breathing non-fueled intake with exhaust that feeds the compressor tank?
  7. Krazy Comet
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    Well I'll be a monkeys uncle. Just goes to show how inventive people have always been. That and just how many variations of the internal combustion engine there are out there. I like it when things come back around into fashion and the companies selling them try to make people think it's new technology. Ahh.. capitalism at it's finest. Gotta love it.
    PS. one guy in that link said something about a 460 conversion. I want one for my shop compressor! hahaha
  9. Krazy Comet
    LOL, with at least a .650 lift & 280* duration cam??
    With intake blocked and aux intake ports drilled into head, along with exhaust rockers removed, one could push lots of air out the spark plug openings... Some type of reed/one way valving would be necessary...
    groberts101 likes this.
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    I have a pretty good imagination.. but imagining the sound of a reed valved 460 eludes me. Maybe a bit like a HUGE rotax motor? :bouncy:
    Krazy Comet likes this.
  11. Krazy Comet
    OUoohhh, now my head is starting to hurt..
  12. RMiller
    Kennewick, WA
    I guess my job here is done!:biglaugh:
  13. Krazy Comet
    Yeah it always a good day when your head stops hurting -- or learn something..
    RMiller likes this.
