Happy B-Day to me....
Discussion in 'Non-Ford Engines' started by 71gold, May 22, 2019.
  1. 71gold
    Effie asked what I wanted for my birthday...this is what we are going to Summit Sat. to get me.
    FiTech Ultimate LS EFI 500 HP Fuel Injection Systems 70001
    I Love Her Berry Berry much!!!!! :party3:
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Does she by chance have a sister???:D
  3. stumanchu
    stumanchu Stuart
    Portland, OR
    Happy birthday Frank! I hope your car starts when you go pick up that bowtie food dispenser.
    Krazy Comet likes this.
  4. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Happy Birthday Frank
  5. 71gold
    thanks...me too.
  6. 71gold
    thanks...:Handshake:
  7. yellow75
    Tillamook Oregon
    Well you made it to another year and at least your safe from the plaque that haunts your car. Happy Birthday Frank and hopefully many more
    71gold and Wilbur Green like this.
  8. Earl Branham
    Lugoff, SC
    Happy Birthday buddy, hope you have a great day! Looks like you off to a good start!!!:birthday2::blowhorn:
  9. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
  10. 71gold
    thanks everyone...:Handshake:
  11. 71gold
    after pulling the system from the box and assembling it....
    I found one thing I could not live with...the wiring harness.
    the pictures showed only a small harness but when I pulled it from the box...:slap:
    here is a pic of before and after...zoom in. the advertisement pic was about 4 feet long and the size of your finger.
    the one I pulled from the box was up to 8 feet long and big around as your wrist...:yup:
    sticking with my MSD Atomic.
    maybe the ghost swapped them...LOL
      File size:
      207.9 KB
      File size:
      211.4 KB
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    Oh my.....There is more wire there than in my whole car......and I already know that wires are lonely critters in your engine bay....at least visible wires.
  13. 71gold
    thanks...
    at the left in the pic there is an 8 fuse 2 relay panel. the wires stick out the back side about 2.5 ". there is no way to get the block close enough to a surface to mount it.
    I may call FiTech Tuesday and see if I can eliminate it...:huh:
    I think the fuses and relays I have protecting the Atomic EFI , fuel pump and fans will be enough to run their system.
    the intake and throttle body were a compact setup, it's only 7" tall. that and the injectors tucked in nice to the sides, that part would have looked sweet on my engine...:thumbs2:
  14. Xplane
    Xplane Member
    SoCal
    Lots
    Frank, have you outgrown the MSD system?
    That intake is really slick looking! I like that you can support up to 750 hp with just a throttle body and injector swap, assuming the rest of your fuel system can handle it.
    I would think you could mount that fuse/relay box with two stand-off spacers and long fasteners to give you enough clearance for the wiring?
    I was looked at a similar setup for 351w package I’m planning to run. Throttle body mounting is similar with a low profile distributer. The manifold on your system is much more compact. By my measurements it wouldn’t fit under the oem grabber hood, and that is a hard requirement for me.
  15. 71gold
    "Frank, have you outgrown the MSD system? "
    not "outgrown", just changing up something...LOL
    "By my measurements it wouldn’t fit under the oem grabber hood, and that is a hard requirement for me."
    on my Ls the Atomic is 2.5" taller. and I'm running a stock Grabber hood.
    that was a hard requirement for me also. that's why I went with the Atomic EFI to start with.
    with a carb I had to scoop a stock flat hood or run a cowl induction hood.
    this is part of my hood collection...
    stock Grabber hood
    scooped stock flat hood
    carbon fiber Grabber hood
    Jimmy2gates fiberglass induction Grabber hood
    2 more...the yellow original paint Grabber hood was given to me...:party3:
