Harbor Freight 3 Ton Floor Jack Failure WARNING!!
Discussion in 'Tool & Shop Talk' started by rotorr22, Dec 22, 2014.
  1. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    I would take it back Jeff. They will replace it no questions asked or give the $ back. The sad thing is that probably a reasonably priced floor jack from Summit is most likely made in the same factory as a Harbor Freight jack. I know this happens because I imported from overseas as a business for 14 years until I retired.
  2. rthomas771
    Mel, The trouble is making another trip back to the store to make things right. HF is 20 miles from my house or 40 miles round trip...wasn't worth the time and gas for a $3.00 tool. Anyway one drop of Crazy Glue got me back in business
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I don't trust anything made in China.
  4. Mel Moeller
    Twin Falls Idaho
    You had better start looking at labels of everything that you buy then and get used to going without.
    blugene and mojo like this.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    My floor-jack is made in USA.
    I am aware that a bajillion things are made in China, but anything I'm trusting my life & safety to will not be made in China.
  6. Mel Moeller
    Twin Falls Idaho
    I prefer Made in the good old USA too, but sadly my point is that almost everything is made overseas now. Even most of the things that we assume are made here.
    blugene and Crazy Larry like this.
  7. 71gold
    not only...jackstands...Harold had a 4 post lift blow a cyl. and when it fell his roll around tool box that was under the lift, held up one side causing the 65 Mustang vert to slide off on it's side...this was a commercial lift... :yup:
  8. 71gold
    I had a part once that had...made in U.S.A...on the box. at closer inspection I noticed it said...box made in U.S.A....:yup:
  9. Mel Moeller
    Twin Falls Idaho
    A trick now is for the selling companies to put "Designed in the USA" or "Engineered in the USA" or something similar so people will read over it.
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Also, "Assembled in USA".
  11. darren
    Glad you had sense to use a stand. jacks use stands and hoists have locks. Never leave a hoist between locks. Always drop it onto the lock. Unless you dont mind being a few inches shorter.
  12. 71gold
    ...and make sure weight is on all four corners...I was letting it down when I saw it...:yikes:
    must have been the frame connectors that saved it...:yup:
      File size:
      93.4 KB
  13. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Bingo! Went to Summit today. Both the Summit branded steel and aluminum jacks are "Made in China".
  14. mav1970
    Tough to find anything not made in China these days - some of the HF hand tools, I'll trust for lighter use but won't be surprised if it fails - I had a 1/4 inch drive ratchet break putting the first socket on it - it took a trip down the driveway
  15. John Holden
    John Holden Member
    NJ
    Be careful buying anything with "moving parts" from harbor freight. I bought a 4" angle grinder just to keep at our summer place. The bearing desintegrated in less than a minute the first time I used it. Some stuff is ok to buy from there. Just remember, you get what you pay for.
