Hard start only when hot
Discussion in 'Technical' started by Chadwick powers, Sep 30, 2015.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Aluminum conducts heat, so it's really not helping at all. A Phenolic or composite spacer would reduce heat some, but even that may not solve the problem.
  2. Chadwick powers
    Chadwick powers Keeping it old school
    ca
    1974 ford maverick
    Ok but driving this almost every day for a year no problems tell last week with starting an today start up fine all day so I'm confused help
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Well it sounds like a flooding issue, and since it never had that problem before, it's probably not caused by heat (although heat will make the problem worse). I'd refer back to the suggestion that you may have a needle/seat not completely closing off the inlet of fuel. I'd probably go through the carb before doing anything else.
    Does the carb have a choke? And if so, is it fully open when the engine is hot?
  4. Chadwick powers
    ca
    1974 ford maverick
    I'm going start going through the carb tomorrow
  5. Mavman72
    Do you buy your fuel in at the same place all the time??? Same octane rating each time??? It could be a fuel formulation/octane issue as well. But... Most likely as stated above. Check your float setting cold and hot before you start tearing things apart. Allways do the diagnostics that dont cost you money/disassembly before tearing into stuff.
    You can stop alot of a heat soak issue by, blocking off the heat riser passages in the heads that feed hot air to the bottom of the intake under the carb.
  6. Chadwick powers
    ca
    1974 ford maverick
    Already done all that I go to same gas place every time
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Crazy Larry is correct. An aluminum spacer will do next to nothing to insulate the carb. Try a composite, it could be an inexpensive remedy.
  8. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
  9. Ronald Hopkins
    1972 Comet GT
    I didn't mean to say it would cure a hard starting problem. I just meant that it was a good write up on how to use a vacuum gauge.
  10. Krazy Comet
    Ron I wasn't questioning you assessment of use of the vac gauge, I agree it's a good article...
    Ronald Hopkins likes this.
  11. Russell
    Russell Orejano
    New Mexico, 88022
    Maverick
