Harmonic Balancer Question
Discussion in 'Technical' started by mojo, Dec 14, 2014.
  1. mojo
    My harmonic balancer has some of elastic/rubber protruding, the rubber has cracks; wondering if that is a sign the balancer needs rebuilding/replacing? My car has a vry slight vibration that can only be felt through the gas pedal. Wonder if this cud be possible cause?
  2. Bryant
    that is a possibility. i would replace it. they are not very expensive.
  3. mojo
    Thanks for ur input Bryant. Always appreciated. I might have said in the 1st. post "I have a slight vibrations", I probably shud have said, more like a very slight buzzing sensation". What do u suggest, have the unit rebuilt or go w/ one of the aftermarket products. I know the unit I have will go back on w/o any fitment issues. I wud like to keep it that way. I have never had one rebuilt, so, don't know how they usually preform. I've heard a lot of pro's/con's on a lot of the offshore parts - kind of leaning toward trying the rebuild route.
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
  5. Krazy Comet
    If the engine is basically stock I'd use a stock replacement... With rubber hanging out, no doubt what it now has... Probably original?
    Advance has Dorman for $85.00, probably find one on ebay for less...
  6. mojo
    My setup is basically stock, mild cam, headers and 600cfm - cruiser. I think a stock setup is all I need.
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I purchased one of the non-SFI Summit branded balancers. It is a surprising value for the $$$. It has timing index marks that will accommodate A, B or C position pointers.
  8. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    A new balancer is also going to make the eng last longer even if this is not your problem,so you`re not really losing anything as far as money goes.
  9. mojo
    I hear you Dan! That is on my things to do list as soon as the spring season arrives. I have been driving it to long w/ that being a concern. I don't know if that is the reason I feel the buzzing sensation thru my gas pedal, but it might be. My nx guess wud probably be flexplate/torque conv..
  10. mojo
    Is this the one that u purchased? I like the fact it has spacers/washers needed to make the job simpler. http://www.summitracing.com/parts/sum-163289/overview/make/ford
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Yes. I'm using a March serpentine system and did not need the spacers. Make sure you order the correct P/N for your engine (28 oz or 50 oz).
  12. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I had that same balancer on my last motor, I sheered the pulley bolts on mine a few times even with grade 8. Also didn't care for the spacers, makes it hard to install the crank pulley.
  13. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Why were the bolts so heavily loaded in sheer? Sounds as if the bolt torque was lost.
    I agree the spacers are not a great design. My March crank pulley bolted up directly to the balancer, requiring very minor shimming of the water pump pulley for belt alignment.
  14. 71gold
    does your stock balancer have spacers...:huh:
    one of the reviews..."Nice damper. Don't care for the spacer, the instructions for the spacer dont make sense and are incorrect. Tech guys couldn't help."
  15. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    It may have been what was happening, but the second time round I installed them with blue lock tight and they still broke. Another thing I didn't like about this balancer was the timing marks that I needed were on the inside, which make it very hard to read.
