Having engine heat issues - need advice
Discussion in 'Technical' started by mrmalina99, Jul 9, 2016.
  1. mav man
    mav man Member
    wi
    70mav
    I have to agree that 10 degrees at idle was usually the stock settings,i think mine is at 13 or 14 at idle and at about 35 degrees full advance.id hook up a temp gauge and then you can see actual temperature
  2. m in sc
    m in sc Member
    rock hill sc
    how rusty is block? if it had crud in it may have clogged radiator over time.
  3. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    I would suggest that you get a temp gauge. Without one you are shooting in the dark.
    mojo likes this.
  4. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Do you have "The rest of the story"? Just wondering if you solved your problem, as these overheating problems keep popping up with various members. Thanks.
    MD
  5. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I added a temp gauge and discovered car was getting to 230 before I would get off highway. I bled the cooling system but have not had a chance to test. I am focused on finishing my 1970 Mach 1 restore at moment. I will provide update when I have one.
