haziness on windows
Discussion in 'General Maverick/Comet' started by lilfarley, Aug 11, 2008.
  1. blugene
    This is how it begins...:rolleyes:
  2. Mavman72
    you should do the glass when you do the headliner, since the correct installation of the head liner requires it to be wrapped around the pinch weld in the window channel.If all else fails... safelite can get you a windshield and install it after the headliner is in.I am sure there are other sources but Safelite is a national chain...
    Good luck.
    And this is how it continues:stirthepot:
  3. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    i am just doing my own with some mole hair velcro and some spray can adhesive it isn't a permanent thing just something to get me by until i have more money to go back over doing a really good job on it. it doesn't sound like it will look good but i have been doing some messing around and i think it will look decent (y)
  4. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    If the reason the windshield gets hazy because there is two pieces of glass, then why is my back glass "discolored"?
  5. mleech7825
    mleech7825 Member
    Kansas
    1971 Maverick Grabber
    When we bought our Mav, it had a decal on the top of the windshield. We removed it, but there is this blueish shadow of it on the windshield. Is this the same problem, it's on the plastic between the glass?
  6. Mavman72
    Your windshield most likely has the factory tint at the top.Its the plastic between the glass too.(its colored"tinted")plastic laminate.Or your glass is stained from what ever was applied over it.
