Head Light Relay Update
Discussion in 'Technical' started by mavdog71, Apr 5, 2009.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Why go back to the dimmer switch for the relay trigger though. Trigger them from one of the existing headlight plugs.
    Like Frank said if something happens with the relays, simply plug the headlamps back into the stock headlight plugs. You will then have your old dim lights back.
  2. rthomas771
    Didn't say go back to the dimmer switch...the trigger wire is coming from the dimmer switch to the relays. If something happens to the relay...unplug the relay and connect a jumper wire with a spade connector on each end between the #86 and #87 sockets.
  3. maverick1970
    Missouri
    Your diagram shows the connections at the Beam Selector Switch
  4. rthomas771
    I'm missing what you're saying .:huh: Yes, the trigger wires (#86) power comes from the Beam Selector Switch, this is small amp power to pull the relay closed. The BIG amp power (#30) to light up the headlights comes from the battery and it will pass through the relay (#87) to the headlights after it is pulled close from the trigger wire's signal. The relays are mounted close to the headlights. :Handshake
  5. maverick1970
    Missouri
    I am well aware of how it works.
    The drawing you posted indicates that the trigger wires should be run to the beam selector switch. I am saying you can simply connect the trigger wires with a spade terminal to the old unused headlight plug. (which come from the beam selector switch) Since the relays are mounted by the headlights you can run 18 inches of wire rather than 9 feet.
    This is probably what you meant but the drawing doesn't indicate that.:tiphat: Just trying to simplify the installation for the not so savvy.
  6. rthomas771
    I see what you're talking about now. You confused me with "the going to the beam selector." The trigger wire electricity is coming from the beam selector...not going to the beam selector. It is going to the relay (y). I cut the wires going to the headlights and put in the relays. I have heaver 10 gauge wires from the relay to the headlights (less voltage drop). The idea wiring of electricity is to eliminate as many connections as possible. One could use the headlight plug for simplicity but the spade connectors would eventually start to corrode and oxidate over time. :Handshake
    Anyone looking into doing the modification...You can buy a 2 bank relay kit from Painless for $164 or you can get a 2 bank relay from a late 80's early 90's Dodge Caravan with a rack to hang the relays at the junkyard for $5 or $10. Be sure to get as much wiring harness as you can
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Also Gen II S-10/Blazers have a realy nice set of weatherproof (Metri-pak) relays mounted high on the firewall just under the hood, really easy to grab and $10.00 or so (you'll get 4 plus a bracket).
    Russ
  8. rthomas771
    This 5 rack relay is also from a Caravan that I have on my Falcon. 2 go to the fans, 1 to the water pump, 2 to the headlights. The picture above has another 2 bank rack that interlocks with it
  9. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Jeff
    You save a lot of work on my Tech Artical thank you for doing it for my .... JAY:clap::clap::clap:
  10. 71gold
    all you need to do is, copy and paste to the...tech. section...:yup:
    We help when we can...:rofl2:
  11. rthomas771
    You're welcome Jay. I missed the post where you said you was gonna do an artical. Go ahead and copy/paste/edit
  12. 71gold
    "Go ahead and copy/paste/edit and...take credit..."
    ...:D...
  13. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Talk to Jeremy this afternoon will be using his 72 mav for the tech artical ( no engine in it ) for some pic . Will have to wait untill after Knott's and Show an GO on the frist weekend of May .
    Stay Toon more Later
    Jay
