HEAD opinion
Discussion in 'Technical' started by mavmike72, May 1, 2009.
  1. 71gold
    if not done correctly they could flow less...:tiphat:
    "is what i'm trying to say"...:D
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    I guess ill see.
  3. 71gold
    :hmmm:...how will you know :huh:
    ...:rolleyes:...
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    there is no true way to tell how much if any the port job helped without dyno/track (for Frank) :D #'s of before and after.
    Even if you did nothing at all, you got some good experience with a dremel. (y) My hats off to you for giving it a whirl :thumbs2:
    in my opinion, if you just cleaned up the runners and ports, you helped it!
    now you need to port match the intake :rofl:
  5. mavmike72
    mavmike72 Member
    louisville kentucky
    Hell my whole motor is going to be new so it should feel stronger, so lets just say it was the porting i did..............:dancing:
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    that-a-boy :clap:
  7. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    I wouldn't waste my money on stock heads ported or not. My friend just scored a set of assembled aluminum Pro-Comp heads off ebay for $560. that extra $150-$200 is well worth the benefits.
    I have a set of fully ported big valve (1.94/1.60) 69 Windsor heads on my car now but they only flow around 210 at .550 lift. Most aluminum heads flow 240 or better at the same lift. And you lose 50 LBS off the nose of the car. The reason I run the Windsors is because they were free :). However they do make enough power to slam unsuspecting friends heads into the headrest and nuke the tires off in the first two gears :) I am installing AFR 185s on the next motor.
  8. mavmike72
    mavmike72 Member
    louisville kentucky
    Head update
    Well i dropped my heads off today to get finished up. Bull$hitted with the guy for about 45min, he started off wanting 400.00. Before i left he said he would do them for 300.00. So im happy to save some $$$$$$$$$.
    I should get them back next wednesday or so. I cant wait, im ready to get this motor done. :D
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    good deal.....we will be harrassing cruise-in's before you know it!
  10. mavmike72
    mavmike72 Member
    louisville kentucky
    Yea i hope so.
  11. mavmike72
    mavmike72 Member
    louisville kentucky
    Ok i just picked up my heads and the guy has me worried. He said my spring pressure is 135 and that its border line to much, but dont worry. If im not to worry why did he tell me. What do you guys think, should i worry?
  12. Bryant
    its the money concern issue that made him decide to tell you not to worry. the motor will run. it just will encounter valve float at higher rpms. it will limit your top end horse power. if you can afford new springs now would be the time to get them and put them on.
  13. mavmike72
    mavmike72 Member
    louisville kentucky
    They are new.........the one i had were only 85lbs. Every thing is new. The springs i had were stock these are duel springs
  14. DonCARLSON
    DonCARLSON Member
    St.Augustine Fl.
    1970 maverick,1974 Maverick
    Save yourself some trouble and install the correct springs at this point. If not you will be disapointed. Why port heads if you cant pull enough RPMS to take advantage. Good luck!
  15. mavmike72
    mavmike72 Member
    louisville kentucky
    Thats why i took it to this guy, he builds motors. He did everything on the heads, except port them. I did that. I was told by several people that not enough spring pressure will cause valve float. By him as well. So what does boarder line to much pressure cause? He said not to worry but im worried.
